beim Export aller Items. Kommt es bei mir zur folgenden Fehlermeldung im log und der Itembaum wird nicht exportiert.
Es kommt wohl von diesm Item welches 2 Kinder Item hat. Die Kinder Items lassen sich exportieren.
Viele Grüsse
Jürgen
2017-05-01 08:59:23 DEBUG Core Visu: 192.168.102.80:64307 sent '{"cmd":"admin","admin":"exportNodes","path":"haus"}'
2017-05-01 08:59:23 ERROR Core 'NoneType' object has no attribute 'replace'
Traceback (most recent call last):
File "/mfs/core/lib/websocket.py", line 422, in json_parse
self.admin(data['admin'], data)
File "/mfs/core/lib/websocket.py", line 483, in admin
self.admin_commands[cmd](data)
File "/mfs/core/lib/websocket.py", line 700, in export_nodes
filename, ext, csv = self._core.config.export_nodes(data['path'])
File "/mfs/core/lib/config.py", line 552, in export_nodes
csv = lib.csv.create(export)
File "/mfs/core/lib/csv.py", line 80, in create
row = [x.replace('\n', '\\n') for x in row]
File "/mfs/core/lib/csv.py", line 80, in <listcomp>
AttributeError: 'NoneType' object has no attribute 'replace'
2017-05-01 08:59:26 DEBUG EM300:plugins.emhaus Item plugins.emhaus.ActivePowerExport = 78.4 Trigger caller=EM300LR, by=Plugin, node=plugins.emhaus, path=plugins.emhaus
2017-05-01 08:59:26 DEBUG EM300:plugins.emhaus Item plugins.emhaus.ActiveEnergyExport = 1693049.5 Trigger caller=EM300LR, by=Plugin, node=plugins.emhaus, path=plugins.emhaus
2017-05-01 09:09:42 DEBUG Core Visu: 192.168.102.80:64307 sent '{"cmd":"admin","admin":"exportNodes","path":"haus.og.bad.fenster"}'
2017-05-01 09:09:42 ERROR Core 'NoneType' object has no attribute 'replace'
Jürgen
