Measuring fuel level
    Zitat von Warichet Beitrag anzeigen
    The doc says "Öl" I guess it means "diesel" "fuel" ?
    The nice thing, this Koaxialrohre will fit in any tank (no problem for narrow tank )
    Any means to get an idea of the price ? In my case, with Koaxialrohre, 1,6m
    Öl is diesel or fuel
    If you found the type in the leaflet, you can search the price on the internet page, I have given you first.
    I liked the way with the koaxial tubes, because there should be no interfrence with narrow tanks or while filling the tank.
    Andreas
    Alter Hof mit neuer Technik
      Some news about ultra-sonic sensors
      HRLV‑MaxSonar‑EZ
      Looks fine, waiting for more detailed specs.
        Sorry but the link doesnt work.
        Andreas
          Sorry, my mistake
          Their site is Maxbotix www.maxbotix.com
          Their email is marketing@maxbotix.com
          The HRLV‑MaxSonar‑EZ link is Indoor High-Resolution Ultrasonic Rangefinders from MaxBotix Inc.
          The MB1043 MB1043 HRLV-MaxSonar-EZ4 Ultrasonic Rangefinder might be the device I was waiting for since a long time, for a narrow fuel tank. My previous attempt with a similar device was a failure (beam too wide, reaching the side wall before reaching the bottom)
          My ABB AE/A was configured for current loop, I've still to check if it fits with a voltage level, as specified in the specs
            Request for help about ABB AE/A 2.1
            Hello,
            I'm putting a Maxbotix sensor to work.
            I need some guidance to correctly configure the AE/A 2.1. ABB's Tech Sup declinded to help
            Given is the following information.
            The AE/A is connected to an ultrasonic sensor, connected to a +5VDC supply, with an analog output 0-5V
            The sensor is from MaxBotix, model LV-MaxSonar-EZ4, ref. MB1040, MaxBotix Ultrasonic Sensors, High Performance Distance & Proximity Sensors
            range from 6-inches out to 254-inches (6,45-meters) with 1-inch resolution.
            The application is to measure the fuel level in a tank, the sensor is placed at 1,72m from the bottom.
            The sensor scale factor: Vcc/512 = mV/inch, i.e.
            5/512 = 9,765625 = 9,77mV/"
            1,72m = 67,7" = 661,2mV max output voltage, hence we can select the range 0-1V in the setup of the AE/A
            Configuration of the AE/A 2.1 in ETS:
            •A General
            •Sensor type: Current/Voltage/Resistance
            •Sensor output: 0-1V (soit 102,4" = 2,60m = 1V)
            •Lower limit: 0
            •Output value: 0
            •Upper limit: 26 (1,72/2,60 = 66%) 67,7/102,4 = 66%)
            •Output value: 172
            •Factor: 0,01
            •A Treshold value 1: lower 20, upper 30
            •A Treshold value 2: lower 132, upper 142
            Is this the correct configuration ?
            So far, I've configured a treshold to generate an alert when the fuel level reaches low
            How should I handle the sensor's dead zone, i.e. 0-6inch = 6 inch ?
            Thank you for your comments
              Maxbotix Sensor
              Hello,
              Hello Warichet,
              as far as I found out the sensor's price is about €34.- How is your first impression of the sensor? What do you say about the quality?
              I like the price!
              Regards from Spain
              Claus
                other type
                at Amazon I found another sensor with a range of 2 cm- 4 m !! For only ~€18.-
                4-20mA Current Loop Ultraschall-Entfernungsmesser: Amazon.de: Elektronik
                It has an output of 4-20mA
                dimensions: 43mm x 20mm
                Regards Claus
                  Yes, Maxbotix is sold in Europe now
                  Well, the first impression is fine, although I'm still testing the sensor, not yet into production, so I'll wait before I make a definite comment. I was surprised by the size, the sensor is really small.
                  The quality is fine, but, after contacting TechSup for another issue, I learned that the model MB1040 is not recommended for fuel. I didn't see the info in the data sheet :-( A bit frustrating to get the info when it's too late.
                  About accuracy, the specs say +/- 1 inch, my measurements, although not scientific, show a bit more then 1 inch, but it's fine for my application. The main benefit is the very narrow beam, needed in my case (narrow tank).
                  Also, the supply is 5VDC, a bit anoying, I had to build a DC converter (7805). Current loop is more simple.
                    Hi Claus,
                    Have you gone forward with your investigation ?
                    any comments to share ?
                      Hi Claus,
                      I've spend some time adjusting and calibrating the MB1040 together with a ABB AE/A 2.1
                      I've done the tests in an office environment, simulating exactly the fuel tank.
                      I've been piling up/removing carton boxes to simulate different fuel levels.
                      My conclusions are:
                      the device is quite reliable and accurate, although I observed measured values slightly outside the specs, but no problem for my application.
                      I've put the device into production, and got a very bad surprise
                      the sensor says: 0,40m
                      measured: 0,49m
                      This is NOT a setup problem as it worked perfectly well in an office environment. To me, it looks like the sonar beam is detecting the fuel level too soon, hence it is inapropriate for my application.
                      According to TechSup
                      Other reasons that may cause target inaccuracy is in the LV-MaxSonar-EZ sensors are: Temperature Compensation, Target Size Compensation, or the Sensor calibration itself.
                      So, those low cost sensor don't compensate for target size, this might be the problem. Awaiting a recommendation to buy another device.
                      Grmbl
                        Hmm, very unsatifying, though I'm still in the same "trap" still - first I chose the expensive one and failed..
                        I have some tests running but please don't expect results within the next 12 months - US looks very promising, but I'll never recommend anything again that hasn't worked at least 6 months here
                        Makki
                        -> Bitte KEINE PNs!
                          measured: 0,49m
                          The difference can be caused by the different speed of sound in different athmosphere. You checked it out in plain air, but above the fuel level, you have another athmosphere with a slightly different speed of sound.
                          If you compensate the result by the factor 1,225 (0,49/0,4=1,225) the results for other hights might be right again.
                          Andreas
                            Indeed, that's what I've been told by TechSup, but a difference of 20% on a length of 49cm, isn't that a bit much ?
                            I thought about it for a while, but your suggestion implies the deviation is linear, I mean, a steady percentage, independent of the length.
                            Implementing the trick is no problem, as I use the HS already to calculate the fuel height (the sensor measures only the air above the fioul, not the fuel height).
                            Thank you for your comments.
                              thinking about it, you must measure the highest position and the lowest and set them as the limits in your analoge input. Then you should get better results.
                              The difference can be quite substantial, in 20°C Air, the speed is 343 m/sec, in Helium 970m/sec,
                              in oil(liquid) 1340m/sec.
                              Oil-Dust is not listed.
                              Andreas
                                Another measurement principle (hydrostatic pressure), hence another sensor.. However, cost probably not favourable but robust.
                                Pegelsonden - TECSON
