Gira TKS - Integration without Gira HomeServer
    HS/FS Gira TKS - Integration without Gira HomeServer
    I'm sorry my post is in English. However, feel responded in German. Google Translate will help. :-)
    I have a Gira TKS (2 Türstationen, Steuergerät Video, Gira Codetastatur, Gira TKS-IP-Gateway).
    I would like to integrate this solution in my home automation (OpenHAB) without using a Gira Homeserver. I am aware this is not easy, but I am hoping that the Gira TKS-IP would "open" enough to allow integration with other solutions then the Gira HomeServer.
    More specifically, I would like to:
    * Get some sort of signal when someone rings the door (via HTTP, MQTT,...);
    * Capture a picture. The adres is http://IPADRESS:88/cam01.jpeg. However, when I access it trough a webbrowser, I get a "not authorized" message,
    * Trigger the electronic door opener;
    * Identify who has entered a valid code in the Codetastatur;
    Does anyone have an idea how to do this?
    Is there anyone who can point me in the right direction?
      Did you find a solution? I have the same problem. thanks
      I think you could use a tcp/udp Binding.
      Moadin
      Zuletzt geändert von Moadin; 26.12.2021, 13:37.
