UZSU understanding problem
    HS/FS UZSU understanding problem
    Since the beginning, I've an understanding problem with the UZSU.
    Although I manage to make it work, it's more by accident than by knowledge
    In the Experte, I see the:
    EIB-Steuerung / Universal-Zeitschaltuhren
    Oberfläche / Menü
    On the Client side, I see a menu and actual data entry
    Would someone be so kind to list the right sequence of events (reboot included) with a word of explanation, please ?
    Thank you
    It is quite easy
    In the Experte you setup a new USZU first and add all the commands that you may use within this context.
    E.g: you setup an USZU for the outer area. Within this area you may have serveral outside plugs. Therefore you need two commands: for OFF and ON.
    In the client you can setup several clocks (copies ) of this USZU and you may choose which of the earlier commands you want to use. E.g the commands during weekdays may differ from the commands on weekends.
    Gruss aus Radevormwald
    Michel
      OK, thank you.
      There is still an open question about:
      Oberfläche / Menü
      Should I start with EIB-Steuerung / Universal-Zeitschaltuhren and define the events ?
      Then go on with Oberfläche / Menü and define the commands ?
      Reboot
      Finally, in the client, define the hour/day
      reboot
      Is that correct ?
        The only thing you setup in "Oberfläche/Menü" is the entry for the USZU, which means you create the "Entry" and choose the USZU you want. The rest will be done within the client and/or browser.
        No need to define the commands there.
        So:
        • create new USZU "reboot"
        • add command "reboot" there
        • add menu entry for USZU and choose "reboot"
        • upload to and reboot the HS
        • navigate to that USZU and enter one ore more entries for day and time. You may choose out of the options for sunset/sundown, Holidays, celebration days....
        Michel
          Thank you.
          I'll try not to put both feet in same shoe
