HomeServer and serial Interface
    I understand that the KNX does not support the HS as an interface anymore (unless extra license).
    I guess, that's true for the serial interface as well.
    My config is:
    HS <--serial cable-->Gira FT 1.2 <--KNX Bus-->
    What would be the recommended way for the right solution ?
    Thanks for any advice
    Buy an USB interface from GIRA.
      But you can use the HS as an programming device with ETS5 only by adding the extra licence for Eiblib/IP.
        Hi Matthias,
        Nice to hear from you again :-)
        Thanks
