Webabfrage Agrarwetter
    ich versuche Wetterdaten (vorerst testweise nur die aktuelle Temperatur) von Agrarwetter abzurufen, bekomme aber immer im Event-BiDir immer "HTTP/1.1 400 Bad Request" zurück.
    Kann mir jemand sagen, was ich falsch mache - auch bzw. gerade wenn es ein Anfängerfehler ist? Wäre echt suuuper - ich mache schon eine Weile daran rum ...
    Screenshots habe ich angehängt.
    Gruß und 1000Dank
    Christian
    This gallery has 3 photos.
    I have seen some posts on the http / https topic in the past. Search for that, as I think the HS can only handle non-https web requests. The proplanta site is https. When you enter the url in a normal browser (using the port you specified) you also get the bad request error.
      Thanks for your reply.
      I thougth https is possible since you can enter a port e.g. 443. But if it doesn´t work that would mean that you can´t use the feature anymore because there is (nearly) no website left with just http.
      Or am I wrong? Or what can I do instead?
      Best regards
      Christian
        Sehe mal hier: https://knx-user-forum.de/forum/öffe...r-https-seiten.
          Danke! Ich schaue es mir mal an.
          Christian
            Klingt ganz schön kompliziert :-). Werde es mal versuchen. Danke für den Tipp!
            Christian
              I have a Rasberry Pi (for smart meter data processing) which I also use to do web queries. I find it easier to use that device using some simple Python scripts to query websites, process the data and then send the result as an IP telegram to the HS. You may want to consider that route to solve your requirement.
                I will. But this is totally new for me since I did not work with Python or PHP by now, so I have to start from the scratch. But I will work me through :-).
                Thanks
                Christian
