Eibmarkt N401 settings within HS
    My HS is connected to the bus via an FT1.2
    I've bought an Eibmarkt N401 to replace the FT1.2.
    So far, I've configured the N401 in ETS, it works fine, I can ping the N401 and I can program KNX devices. The busmonitor is OK.
    I'm unable to make my HS work with the N401.
    My project was set-up for a FT1.2, so I need to adapt the parameters under "EIB & iETS" but what should I put there ?
    I see EIBnet/IP routing, but that's not the case
    I changed the PA to put the new PA address
    From the browser, when I try to switch on a lamp, nothing happens, it is as if there is no communication.
    Thank you for any hint
    Hi Raymond!
    It looks bad, you need an IP Router like the Eibmarkt 402. The HS works only with IP Routing.
      Aargh, I should have known better
      There are indeed plenty of posts about the topic, but didn't realize the impact.... until it's too late.
      Nevertheless, thank you for the quick reply
