First Post - LED dimming with 0-10V driver
    KNX/EIB First Post - LED dimming with 0-10V driver
    Hi everyone,
    I have a project that has around 40 lighting circuits with dimmable LEDs with the drivers controlled by 0-10V.
    I see that Merten do an 3 gang 0-10V actuator with switching contacts which should do the job. However I also know that you can get an 8 gang 1-10V actuator e.g. from ABB. This would bring the cost per channel down.
    Has anyone tried using a 1-10V control on a 0-10V driver and if so was did the dimming work OK. Most importanatly did the LED dim down to an acceptable low level.
    reagards
    Nigel
    Hi Nigel - welcome!
    I do not have an answer for your specific question. Most of us do dimming of LED with DALI actuators.
    But let's wait a little bit, maybe one of our users has experience with this combination.
      Hello Nigel,
      I'm sorry but this will not work because 0-10V interfaces work totally different than 1-10V interfaces.
      A 0-10V input acts as a current sink whereas a 1-10V driver does exactly the same so nothing will happen when you dim.
      Or with other words: a 0-10V input expects a control voltage, a 1-10V driver acts like a potentiometer and controls the resistance to get the desired voltage which the device has to deliver. What's missing here is a current source so that's why this setup fails.
      I actually had the same configuration in a test setup. I connected both devices and inserted 24V via a 4k7 resistor and it worked, but not that well. Don't do that at home ;-)
      Kind regards,
      Oliver
        Hi Oliver
        Thanks very much for that. This is very usefull information.
        Regards
        Nigel
