Gira door communication
    Hi everybody.
    I need some help about the Gira Door Communication system.
    I was following a discussion in this forum but I am afraid I became a little lost with too many technical stuff in German
    So, I am asking here for some help in English.
    Here is what I have:
    1 Electric front door
    1 Electric gate
    1 Electric garage door
    2 Electric backdoors
    I also want to be able to:
    -Arm/disarm the Alarm (KNX) with Gira's Keyless in devices.
    -Feed 12v to my whole house audio system to mute the sound when someone is at the door.
    -Open all electric doors with Keyless in devices.
    So, for a fully functional system this is the setup I planned:
    For 'normal' operation:
    - 1 Video control center
    - 1 Videoterminal (main floor)
    - 2 home stations (basement and upper floor)
    - 1 Door station with camera
    For the extras I need:
    - 2 Keyless in fingerprint readers
    - 2 Keyless in code keyboard
    - 6 additional actuators for the doors/alarm/audio
    - 1 additional power supply to feed all this.
    So far so good. But now come the problems:
    How can I connect the door communication bus to my KNX bus? I want to be able to open all doors in the KNX visualization panel.
    I also want to know when some door was opened to perform additional functions (light, etc)
    How can I connect the actuator for the alarm to the KNX bus? Through a binary input?
    I see that the actuators have a binary input. Should I connect it to a KNX binary output?
    Will I solve this with the TKS IP gateway? I still haven't seen info on this.
    Can someone help?
    Thanks.
    you will be able to realize your ideas with the TK-IP-Gateway in connection with the Gira-Homeserver.
    But the Gateway will be available soonest in April 2011.
    Gruss aus Radevormwald
    Michel
      Thanks. That would be great. I don't mind waiting. Is there any info/manual available for the IP gateway?
        Documentation is not available right now, but you may find further Information on Elektroinstallation mit Gira: KNX/EIB Instabus, Sprechanlagen, Gebäudesystemtechnik, Schalten, Dimmen, Regeln. in category News
        Michel
          This might be the link You are looking for, but there is not much information on the IP gateway available. Even on the German page there is not more about it.
          Michael
            Yes, I already saw this later last year. It started stating it would be available in January but I guess they pushed it to April.
            What I would like to see is technical info A manual or similar.
            Also in the price it has several 'licenses'. What are licenses here?
              as I already wrote there is actually no manual or further documentation available for the IP-Gateway.
              But on Gira DCS-IP-gateway you will find that his ideas could be realized in connection with HS/FS
              Michel
                ... you will find that his ideas could be realized in connection with HS/FS
                Only with HS/FS? I am not planning in any of those? Won't it be IP controllable?
                  AFAIK there will be different licences for the maximum number of clients connected to the gateway.
                  Michel
                    How do you want to control the Gateway by IP only? As I understand your plan you want to connect the doorcom to your KNX?
                    Michel
                      Yes I do. But I am planning of using different software for control. Let's wait for the manual to see if it can be done.
                        Not a manual, but... (german)
                        Hello there,
                        here is a link to the web-based-training for the Gira TKS-IP-GATEWAY :
                        WBT
                        best regards
                        Johannes
                          Hi all.
                          I need to get back to this as I will be installing it very soon.
                          So, re-checking: I need to control 5 doors with Gira's door communication system + KNX. I do not want to use the TKS-IP Gateway. It's expensive and does not add much to my requeriments.
                          So, I was thinking in doing this:
                          - Connect all 5 door openers to a KNX binary input module. Then I would activate the door opener with KNX, feeding 12v/24v to the corresponding door opener.
                          Can this be done?
                          Thanks.
                            No one?
