ETS 5.7.x veröffentlicht
    ETS ETS 5.7.x veröffentlicht
    https://support.knx.org/hc/en-us/art...540-ETS-v5-7-0
    New features
    User Interface & Functionality
    • New product and project KNX scheme
    • Support of devices with Modular Application Programs
    • Specific indication for devices with additional Individual Addresses
    • Dashboard->Bus->Configured Interfaces-> import/export
      Dashboard->Bus->Configured Interfaces-> search
    • Drag'n'drop from Group Object to Group Object invokes the 'Link with' dialog
    • Group Monitor: open multiple telegram files simultaneously
    • ETS Product Catalog: shows recent imports
    • Project export (from ETS Professional) also possible for ETS Inside licenses
    ETS SDK
    • N/A
    Improvements
    • Local copy for checked out projects
    • KNX Secure
      • Handling of FDSK strings encoded in QR codes
      • Handling of tunneling services for bus interfaces
      • Automatic disconnect + (re)connect upon modification of security related settings
    • Improved handling for Datapoint Type 251.600 (RGBW)
    • Manufacturers sorted by Manufacturer Name (used to be by Manufacturer Code)
    • Merge of the options 'Update from Online Catalog' and 'Update from Product Store'
    • Import of projects signed by manufacturers
    • Transfer of ETS Inside projects containing devices with activated BCU key
    • Issues with data from the Online Catalog after download, do not prevent ETS from starting
    • Up to date 'interfaces' list included in the ETS5 setup
    • ETS Catalog indicates also changes for devices without Application Program
    • Project properties available as tooltip in the project dashboard
    • KNX/IP devices that are copied have the 'Obtain an IP address automatically' feature set by default
    • New project 'Create line 1.1' option also persisted when ETS closes
    • Newly added devices not assigned to a line, get the Individual Address -.-.- (instead of -.-.1)
    Bug fixes
    • Uniqueness of device serial numbers checked
    • Correct date for project import indicated
    • Sorting of pasted Group Addresses within a new middle group persisted
    • Maximum APDU length for bus communication limited to 239
    • Proper download of specific product selection from the Online Catalog
    • Parameter dialog: 'Highlight changes' feature indicates all changes made
    • ETS App Extended Copy:
      • Replacing Group Address texts keeps the Group Address settings intact
      • Deactivation of the 'Automatic' option unchecks the 'Reset' checkbox
    • ETS App Split & Merge:
      • Group Addresses kept intact when merging
      • Devices can be added in a split line via the 'Add devices' button
    • Parameter dialog: correct representation of parameter values
    • Read device information via the Group Address view properly invoked
    • ETS App icons on the main toolbar grayed out when not licensed
    ETS SDK
    • N/A
    Man man man, Secure wird noch immer nicht vollständig unterstützt.
    Wir werden da meines Erachtens wieder als Tester missbraucht...
    Frank
      Ja, und als besonderes Goody funktioniert die Projektaktualisierung nicht
        so was mach ich nun??????
        Projektaktualisierung funktioniert nicht!!!!!
        hab jetzt diese auch so tolle Update gemacht, kann damit aber nichts anfangen da ich kein Projekt mehr öffnen kann
        ganz tolles update
        Wie kann ich das wieder rückgängig machen
          Bei mir hat alles klappt.
            zwei Projekte kann ich öffnen von 51 das ist nicht wirklich im Sinne des Erfinders
            man kann die Projekte auch nicht exportieren, um vielleicht die ETS zu löschen und die alte wieder zu installieren
            Zuletzt geändert von Yggdrasil; 28.02.2019, 11:18.
              Yggdrasil Dann mach ein Ticket bei der KNXA anstatt hier in deinem ersten Post so rumzuschreien.
                ich schrei hier nicht rum! ich bin grad nur bisschen angepisst, da ich morgen zu einem kunden soll und nichts geht
                  Yggdrasil Würdest du bitte bei der KNX ein Support Ticket aufmachen? Das ist definitiv kein allgemeines Problem; ich habe inzwischen schon problemlos dutzende von Projekten aktualisiert.
                    Also bei mir funktioniert sie. Ich konnte sogar ein unter 5.6.6 (und davor) noch von der ETS als corrupted angezeigtes Projekt mit der 5.7 erfolgreich aktualisieren und wieder laden.
                    Jetzt kann ich mich gar nicht so richtig entscheiden, welche der Versionen nun "besser" ist...
                    Zuletzt geändert von evolution; 28.02.2019, 11:35. Grund: Typo
                    Frank
                      Zitat von Yggdrasil Beitrag anzeigen
                      ganz tolles update
                      Naja...
                      Aber lassen wir das jetzt und lernen daraus:
                      Vor einem Update wichtiger Komponenten immer ein Backup machen und diese nie ausführen, wenn man in Kürze darauf angewiesen ist.
                      Gilt nicht ausschliesslich, aber explizit für die ETS, weil diese als Spartensoftware naturgemäss weniger ausgereift auf den Markt kommt als vielleicht ein Word.
                        Q
                        bzw. einen Reserve PC hat
                          Hmmm, der Gruppenmonitor steigt bei mir neuerdings nach einiger Zeit aus, wenn als Schittstelle IP Routing gewählt wurde...
                          Ob der Gruppenmonitor der ETS wohl auch bei IP Tunneling aussteigt und wann? Und wieviele Verschlimmbesserungen werden wir noch erleben?
                          Frank
                            evolution was heißt "steigt aus"? Crash oder einfach keine Telegramme mehr? Wenn letzteres, würde ich auf ein Netzwerk-Multicast-Problem tippen (IGMP snooping).
                            Gruß, Klaus
                              Ich will nicht ausschließen, dass die ETS seit der Aktualisierung auf 5.7 ein Multicast-Problem hat.
                              Frank
