My HomeServer doesn't talk to my KNX network anymore.
These last days, I've had serious problems with my KNX network due to severe storm, lightnings and several power cut.
So far, the KNX part is working again, that is I can switch lights on and off on both segments via push-buttons, the monitor works but I'm unable to send commands from the HomeServer Visu, no error message, no feedback, no icon change when a command is triggered.
Also, I messed around with the KO, so I don't know the right values 50000 - 500002 or is it 50001 - 50003. With which parameter should this match ?
Can someone help me troubleshoot my network or list the steps I should check ?
Thank you
Thank you
