Heating/Cooling Module made by Matthias Schol
    HS/FS Heating/Cooling Module made by Matthias Schol
    Hello
    I have been using the module (named Lufterst...) for last few years succesfully. (Thank you Mathias)
    Since I dont speak/read german the use of the module is based on google translate. But I cannot implement it fully.
    My setup -
    HVAC control - Fan 3 stage(Its a ABB FCA), controlled by ABB solo). As you can see in attached pic the ETS points.
    I thought that by sending "1" to address 2/1/1 will make fan speed 1, sending "1" to 2/1/2 will make fan speed 2 and sending "1" to 2/1/3 will make fan speed 3. I am able to test this by sending these bits to the bus directly. I am unable to do this using Mathias module. (I assumed that the quadclient module will do that).
    Can you help me in setting this us properly.
    Thank you.
    nitin
    This gallery has 4 photos.
    No answers?
    Do I need to put in more info or is it because of English?
    Paging Matthias...
