Too happy, too early :-|
> Under both tabs 'Gira 1024 ...' you need to set the starting point for the visu,
Yes, OK, I forgot
> so the page where you want the user to start.
OK
Thanks to both
The errors during transfer are gone :-)
There is still an issue with the Visu.
To make sure, I reboot the Visu and the HS, I wait for the first beep, and some later, the 3 double beeps.
At that time, everything looks fine:
the icons are there, I can navigate the tree, up & down, but nothing happens, it is as if there is a missing connection, or a password mismatch.
I'll check if the log can teach me more
Yes, OK, I forgot
OK
Thanks to both
