- √ - Back-up / Restore
    HS/FS - √ - Back-up / Restore
    I've made a mistake in my project.
    How can I look into a backup, without restoring the project, just to read and write down a parameter, go back to the current project and correct the mistake.
    Thank you
    Try to make a copy of the backup folder, rename it and open that renamed project.
    Gruss aus Radevormwald
    Michel
      Thank you.
      I'm a bit scared by this restore option. It's not clear to me what is what, and what should be selected in case of a restore.
      Also, I'm doing a backup of the project since years, when I tried to open it, I got a message "this is not a valid project" ûû
        You should have backups in
        "C:\Users\xxx\Documents\HS+FS Experte 2.6\Projekte\your project"
        the projekt file itself named *.hs3bak1 and the referring folders "*.bak1"
        You should be able to rename the project file to NEWNAME.hs3 and the folder to NEWNAME. To keep the original backup, copy and paste that file and the folder first!
        The open the Experte and the Projectfile "NEWNAME.hs3"
        This should make it.
        Michel
          Thank you very much
            If successful, please mark this thread as solved
            Michel
