- √ - HS and camera Cisco CIVS-IPC-2500
    Zitat von makki Beitrag anzeigen
    -> wireshark, capture what happens, how User/PW gets to the cam..
    As you mentionned several times, it's all about Basic Authentication, so I tried to make a definite point about that item (otherwise the remainder of the reasoning will be false)
    I'm using the following URL syntax:
    http://admin:1234@10.x.x.x/img/video.mjpeg
    In IE8, IE9: not allowed (MS knows better what is good for me)
    In OpenSuse, FF: the URL is interpreted (not executed) and I end up in another web site, this is crazy !
    In Ubuntu 9.10, FF: same as above
    In HomeServer, xxAPI, xxHTTP: no result, but it's not known if Basic Authentication works, so no conclusion.
    HS setup for the test:
    Kameras:
    see tuut1
    NB: the account "gira" has been defined in the cam
    Benutzer:
    I don't know in which user context the connection takes place, so I suppose "guest" (but did it for my account as well)
    see tuut2
    Camera setup for the test:
    An account has been created that matches the setup in the HS "Kameras"
    The capture has been taken just before hitting the button in the Visu (Ubuntu+FF) and before the pop-up.
    NB: the WireShark PC has been connected to a port of the switch which "mirrors" the port of the cam, hence solely traffic intented for the cam has been recorded.
    see tuut3
    Here it is, be prepared for a surprise
    https://rapidshare.com/files/2762174089/Camera.pcap
      In yet another attempt to solve my problem (I'm kind of "die hard massochist" ), I've installed Google Chrome on yet another PC.
      Chrome does accept the basic authentication syntax in the URL, i.e. http://<username>:<password>@<ip address>
      Unfortunately, it doesn't work, I get a message back about "site not found".
      It looks like basic authentication is not supported by the cam.
      Is this the end of the long road ?
      When I make a mistake in the password, I get another error, bizarre, it looks like basic authentication is accepted ?!? but not honored ?!? bizarre !
      I changed my password in the cam, it was a "real" password with small letters, capitals and it did contain a hash sign (#).
      It works.
      So, it's not a basic authentication problem, it's a password problem where some signs are interpreted.
      I've entered the new password in the HS, Kameras properties and the Kamera Direckt Zugrif check box still checked for user guest (although I still fail to undestand those settings in the case of a browser access).
      Still no go.
      The alternative via xxHTTP with basic authentication in the URL does work ! but then I've a page formatting problem, which I'm going to ask here in the xxAPI forum.
        Might sound smart-aleck (Neunmalklug, got that from dict.leo.org) now and is less secure: but never use any special-characters besides a-Z/0-9 in such passwords. Passwords are bad anyway, so if the device is properly secured (by network/IP) this doesn't matter.
        http://user:password@hostname/page
        works AFAIK in any browser/OS, thats written in some RFC and simply true (it also works with special chars in passwords, but they have to be escaped properly - and this is where trouble starts..)
        Chrome and any IE accept this syntax either pretty well, because it's a pretty simple base of the HTTP-Standard. (it might still be that the cam doesn't, in your capture there's only the part until the browser would ask for credentials)
        Makki
        -> Bitte KEINE PNs!
          In the mean time ...
          I've upgraded the Visu PC to Ubuntu 10.04 and FF to 7.01.
          Now I've the camera stream nicely displayed in the HS Visu.
          Next step is to record the stream on the NAS.
          The cam has 3 applications:
          • e-mail
          • ftp
          • http
          all being triggered by an event, i.e. motion control.
          I guess I've to write a php script triggered by the http application to start the recording to NAS (same question here).
          How do you guys do it ?
            Off-topic: http_post, http_get, php
            Would someone be so kind to point me to some readings about http_post, http_get and php, please ?
            So far, I was using the W3schools site for my learning but it's not detailed enough for my current project. I want to learn more about those topics for integrating the cameras, NAS, HomeServer and eibd.
            I've a problem with http_post, http_get and enumerating the content of the camera reply.
            Some how, I've to get started but I don't even know the number of parameters in the cam's reply.
            I know there is a a special syntax to get the elements of the reply but there I'm stuck. I've a serious lack of knowledge here
            First, I'd like to make sure if the cam uses get or post. How can I do this ?
            Then, I'd like to enumerate all elements of the reply, eventually handle a 2 dimensions table and select the element appropriate to trigger the writing of the cam data stream to the NAS.
            Any suggestion ? or code sample ? or documentation about the topic ?
            Thank in advance.
              Again, you best friend is Wireshark, he knows what really happens
              It's often not easy going but in the end - if you figured out what really happens - it's getting clear what has to be done to get the beast done..
              Have no such cam but the way is always the same: find out what it does.
              Makki
              -> Bitte KEINE PNs!
                I moved a bit forward.
                Now, when I pass under the cam, a lamp goes on.
                That means: the cam, ftp, eibd, N148, NAS are technically working.
                So, when the cam detects a motion control, it triggers a php script that calls eibd and switches a lamp On.
                Now the question: what is the best way to write the video stream to the NAS (ftp) in case of incident ?
                NB: I can configure the cam to write to an ftp server or send an e-mail at each motion detection, but that's not what I want.
                I want the video stream to be written ONLY in case of intrusion.
                How to you do it ?
                Thanks for any hint.
                  RTP/RTSP protocols
                  I did RTFM again. I read that the cam can deliver 2 video streams. I was thinking about:
                  - one for the HS Visu
                  - one for saving to the NAS archive per ftp
                  Is that correct / make any sense ?
                  I'm reading also that the cam supports the RTP/RTSP protocols. According to the doc, this feature could be used to manage / redirect the video stream, but there it stops....
                  Anyone having a practical experience or example and want to share it ? or a pointer to a meaningfull doc (I know Wikipedia).
                  Thanks
                  RTP/RTSP
                  RTSP Port
                  Transmission Control Protocol (TCP) port on which the IP camera receives Real-Time Streaming Protocol (RTSP) commands. You must configure this port to allow third-party devices or software to access video streams from the IP camera.
                  RTSP is a standard for connecting a client to control streaming data
                  (MPEG-4) over the web.
                  Valid values are 554 and 1024 through 65535. The default value is 554.
                  RTP Data Port
                  Universal Data Protocol (UDP) port on which the IP camera transmits Real-Time Transport Protocol (RTP) data.
                  RTP is a standard for transmitting real-time data, such as audio and video, to a selected clients.
                  Valid values are 1024 through 65535. The default value is 5000. The default value can be used for multicasting and typically does not need to be changed.
                  Max RTP Data Packet
                  Maximum number of bytes per data packet that are sent in each RTP request.
                  Configure a lower number if you are streaming video to a cell phone that
                  requires smaller data packets.
                  Valid values are 400 through 1400. The default value is 1400.
