I'm trying to integrate a Cisco camera CIVS-IPC-2500 in the HomeServer.
I've read many posts about the topic, but I think I've an understanding problem.
I've installed the camera as per manual.
I've configured a fixed IP, a resolution of 352x288, data single stream MPEG-4, write down the path to the picture.
With the browser and a direct access
http://10.0.1.243/main.cgi?next_file=video.htm I can see the picture.
I'm not sure about my settings in the HS, maybe someone can spot the problem ? (with my current setup, I've an empty camera image)
Thank you
Thank you
