Überblick Node-Red Pakete für KNX
    Hi
    if your test was working the first time you added the new configutation gateway node, it must work, because yet all your nodes does link with this new gateway node.
    Have you restarted your machine?
    On what you're running node-red? Pure Raspberry, Raspberry with Docker, Virtual Machine or what?
      I restarted the Rapsberry 2 , works pure on the raspi
      know i tryed something else , i used for one switch the config node of the ip interface and it works , on the multicast it doesnt work at the moment .
      On the Ip interface i grab the measurments of temp an so on
        Please check also not to have two nodes with same group address but different datapoint.
        Then manually select the ethernet interface on the config gayeway. Don’t leave Auto. Choose an ethernet interface and restart nodered
          how can i check this? Please check also not to have two nodes with same group address but different datapoint.
            Either manually by opening all nodes one by one, or by going into the gateway config window and open up the “advanced options”. Below you’ll find a list of all nodes and belonging datapoints.
