After a HS reboot (which I do very often
) the staus in the Visu is not correct.
What would be the best method to have an up-to-date Visu ?
I see several methods (maybe there are more, or more appropriate)
1) object send status every xxx seconds. Looks good, but
- not all applications allow this
- will generate extra traffic
2) send-by-change
- some status don't change very often (some doors, temperature etc). So the wait time to get an update can be very long.
3) manual update
- most objects in the Visu are defined to update their status when they are selected.
Thats the way I use now, but it's not ideal to clic on every status object, to get its last status.
4) polling every so & so
I thought letting the HS explicitely re-reading every status object. Does it make sense ?
Any practical recommendation ?
Thank you.
2) send-by-change
3) manual update
Thank you.
