Miele@Home LBS for Homeserver (14360)
    I have updated the Baustein:
    v1.6 - 16-01-2026 - Miele_14360_v1.6.zip
    * Fixed communications again with Miele API.
    * Added Get FillingLevel (for device), Get FillingLevels (for all devices) and Get Failure Details (for device).
    * Fixed Get Rooms (wasn't working).
    * Lots of cosmetic errors in log and debug messages.
    * Updated Help file.
    * Many edge cases, fixes in renewing authentication, debug output not always shown, and many many other fixes.​
    * Tested on Homeserver/Experte 4.13 (but will work on older versions).
    Zuletzt geändert von Roeller; 16.01.2026, 04:01.
      Hmmm,
      I get an error.
      It tells me "Unauthorized,probably bad username,password,client id,...."
      What Number do I have to add in E7 Device? Is it the serial number?
      My password contains explanation marks as well.
      Can it handle these types of special characters?
      TIA
        This version has fixed the issue.
        Thx Roeller!!!!!
          Zitat von Knochen Beitrag anzeigen
          Hmmm,
          I get an error.
          TIA
          Please follow the help file:
          E7 is serial number of device
          NO special characters in password. I tried it with exclamation mark in password and it doesn’t work, this is because of the Miele API. In their app it works, but not in their API.
          Also follow the get-involved link to get credentials.
            Thx Roeller!!!!!
            Great to hear!!!
              habe die v1.6 eingespielt und die Fehler von Beitrag 101 sind nicht mehr vorhanden.
              Einfaches EIN/AUS über E16 funktioniert nicht.
              Meine Frage in die Runde: benutzt jemand den Baustein unter Version 4.10 ?
              Gruß Sebastian
              Zuletzt geändert von webseb79; 17.01.2026, 12:29.
                Gruß Sebastian
                I didn’t test on 4.10, but if I know what’s wrong I might be able to fix it. Can you turn on debugging (an option in the baustein) and connect a display/monitor to your homeserver and send me a video/screenshots?
                  Würde bitte jemand von Euch vom Logikeditor einen Screenshot von Eurer Integration uploaden, ich scheitere glaube ich schon an der "Grundeinbindung bzw. an der Eingang/Ausgang Belegung.
                  Mein Ziel wäre die Integration der Werte in den Quad (Läuft Ja/nein).
                  DANKE
                  HS3, Russound, iPhone
                    Also ich scheitere immer noch.
                    Miele schickt mir den Link den ich dann abrufe.
                    Client ID und Client Secret trage ich in den Baustein ein, check auf der Miele Webseite "Agree to term of license" und klicke auf weiter.
                    Ich bekomme dann nach etwa 30 Sekunden ein "Gateway Timeout". Jedes Mal.
                    Click ich dann auf refresh bekomme ich die Bestätigung "activated".
                    Versucht mit Edge und Chrome.
                    Nachtrag:
                    Das zeigt nun der Browser auf Android an.
                    [code":500,"message":"Ein technischer Fehler ist aufgetreten. Bitte versuchen Sie es später noch einmal. (Error-ID: c46c65eeb56ba667)"}
                    So weit so gut.
                    Wenn ich die Daten nun in den Baustein eintrage kommt der bekannte Fehler.
                    Ich denke, dass meine Client ID nicht aktiviert wird.
                    Hat noch jemand das Problem mit dem Gateway Timeout?
                    Zuletzt geändert von Knochen; 18.01.2026, 19:02.
                      When you click on the Miele site to agree the terms… I always get that Gateway timeout, then you NEED to refresh to get the successful message, which you really need.
                      please make sure, NO SPECIAL CHARACTERS IN PASSWORD !
                      Looking at the screenshot, I think your device ID is wrong. Most start with a few zeros
                      Look in the Miele app and enter the full id with zeros!
                        That's it.
                        On the Miele website, the serial number was only 9 digits.
                        But the LBS requires a 12-digit number.
                        I had to add the three zeros. Now it works.
                        Perhaps this should be added to the help documentation.
                        Thank you very much.​
                        Zuletzt geändert von Knochen; 19.01.2026, 17:23.
                          Okay, new problem.
                          The LBS seems to be connected now, at least.
                          When I click on "Get Programs", I get an HTTP 400 error message, and under Available Programs, it says "false".
                          Also the information on A3 to A7 ist cut off.
                          How can I read the entire message?
                          TIA.
                          Screenshot 2026-01-19 200133.jpg​​
                          Zuletzt geändert von Knochen; 19.01.2026, 20:10.
                            You can only do a GET_Programs when the device supports it. For example: A washing machine has programs. A Coffee Machine has programs and a Dishwasher has programs.
                            A cooking plate or some other devices don't have programs. I think the device also should be on to get the available programs. If the device doesn't support the Get_Programs (or it is off), you will het the 400 error.
                            I just tested with my CVA7845 coffeemachine and it works.
                            Many people connect the Outputs to a JSON or TEXT baustein. (and use search replace or split lines..etc)
                              You were right.
                              I had to power up the machine in order to retrieve the data.
                              I processed the json with the json building block and the text seperator.
                              Now I have the program IDs and can start the specific dishwasher program.
                              If someone is interrested, I put them in the textbox added in the screenshot below.
                                Hallo Knochen ,
                                kannst du bitte noch ergänzen, welcher Text eingepflegt werden muss im JSON-Parser Baustein (Key) z.B. (Aktuelles Programm gewählt).
                                "programType":{"value_raw":0,"value_localized":"", "key_localized":"Programmart"}
                                Vielen Dank
                                Zuletzt geändert von MarcelAdamsKNX; 11.02.2026, 20:20.
