Node Red: Warn KNX Ultimate GetResources HUE server Id is null
    There is only one light connected to the HUE bridge, but there is also an DeConz server in the network. But different IP and i disconnected DeConz for test.
    But 43 hue device looks like my deconz.
    Marek
      Can you type in something in the HUE field, then send me again the log?
        I would have liked to help with troubleshooting.
        So I installed Huemagic to try out whether my Hue Bridge can be controlled with it. - It worked.
        Then I opened a terminal window (node-red runs in Docker on a Timberwolf server) to see the node-red log file and then configured the HUE Bridge in KNXUltimate. But when I wanted to take a screenshot of the log and the empty device window.... it suddenly worked. 🤩
        My HUE devices were found and can also be controlled via KNX!
        Your HUE module concept is really great, so easy to use. Ingenious!
          Hmmm... maybe it could have something to do with the browser cache. I'll clear the cache via code. Thank you!
            that could be…
            I had completely cleared my browser cache between my first tries some time ago and yesterday.
              Hello,
              used my illness for some tests. with disconnected DeConz Server is it working!
              Marek
