- √ - - √ - HS: Firmwareupdate schlägt fehl
    Öhm, mit Doppelklick auf die .bat funktioniert das zumindest bei mir nicht .
    Also schön manuell in den entsprechenden Pfad gehen und von dort starten.
    Gruss aus Radevormwald
    Michel
      Hallo Mathias,
      das war das Problem !!!
      Danke
        darf ich fragen welchen stand das update hat, und wo ich es runterladen kann. bei dacom ist die version 2.1 auf der hp leider finde ich hier im forum unter download keine dateien wenn ich auf hs firmware gehen.
        danke und mfg philo5
        Guido
          das update findest du auf der gira download seite.
          glück auf
          günther
            I've just done the upgrade (from the first RC). I think I've closely followed the procedure, up to restore the project and re-boot.
            No problem.
            When I use the client, I see the Visu, but I can take no action.
            When I click on an icon, nothing happens, no error pop-up, nothing, it is as if the KO are disconnected from the icons. One icon takes the status feed-back from the KO (instead of from the actuator) and the display toggles, but no action is taken.
            I guess I made something wrong or forgot something, but can't see it.
            Thank you for any troubleshooting hint.
            I'm more and more scared about the HS.
            To my dismay, I noticed that DaCom didn't bother to translate the ReadMe file to english (although not an overhelming effort, imho)
              Have you restored your project with the option "pictures, data,...."
              This is absolutely necessary!
              Second qusetion, release dat eof hs-client?
                Hi Matthias,
                Yes, Sir ! As, stated in the read me file (yes, I do RTFM )
                Mmmm, don't know the version, the properties doesn't say.
                Iit is the one unzipped from the kit, found in C:\Program Files\GIRA\HS+FS\exp22\tools\client hsclient.exe 01/02/2008 09:28
                Thank you for the helping hand
                Bizarre this thing, looks like I've no "execute" rights.
                I'm the only one with this problem ?
                  Sounds really crazy - never seen before.
                  Can you control the HS visu by browser?
                  What does the debug page say?
                    No, just the same as the client.
                    I've tested from another PC, with the client from RC; same thing. Funny to note that, for a dimmer, the Visu show the % brightness, but the lamp is not on.
                    Heuu, don't know where to look.
                    Any particular item you want to know ?
                    I've seen this, but I don't think it is related to my problem
                    11.03.2008 13:13:35 (1)
                    File "/hs/compile/hs_logik.py", line 119, in addFormel
                    File "[string]", line 1
                    __import__('string').replace(SN[1],'"','''')
                    SyntaxError: invalid token
                    [5012L, 13051L, 0L, '', "__import__('string').replace(SN[1],'"','''')", '', 0L, 0L, 1L, 0L]
                      Can you send me your complete debug page? You should have my mail ady...
