usbcore: registered new interface driver usbfs
Jun 24 00:01:07 wiregate312 kernel: [ 6.582168] usbcore: registered new interface driver hub
Jun 24 00:01:07 wiregate312 kernel: [ 6.916137] usbcore: registered new device driver usb
Jun 24 00:01:07 wiregate312 kernel: [ 6.988604] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jun 24 00:01:07 wiregate312 kernel: [ 7.016741] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jun 24 00:01:07 wiregate312 kernel: [ 7.022630] Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
Jun 24 00:01:07 wiregate312 kernel: [ 7.258009] ACPI: PCI Interrupt Link [LNKD] BIOS reported IRQ 0, using IRQ 11
Jun 24 00:01:07 wiregate312 kernel: [ 7.264257] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
Jun 24 00:01:07 wiregate312 kernel: [ 7.270457] ohci_hcd 0000:00:0f.4: PCI INT D -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
Jun 24 00:01:07 wiregate312 kernel: [ 7.283084] ohci_hcd 0000:00:0f.4: OHCI Host Controller
Jun 24 00:01:07 wiregate312 kernel: [ 7.289721] ohci_hcd 0000:00:0f.4: new USB bus registered, assigned bus number 1
Jun 24 00:01:07 wiregate312 kernel: [ 7.302991] ohci_hcd 0000:00:0f.4: irq 11, io mem 0xefffe000
Jun 24 00:01:07 wiregate312 kernel: [ 7.926099] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
Jun 24 00:01:07 wiregate312 kernel: [ 7.933201] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 24 00:01:07 wiregate312 kernel: [ 7.947034] usb usb1: Product: OHCI Host Controller
Jun 24 00:01:07 wiregate312 kernel: [ 7.953937] usb usb1: Manufacturer: Linux 2.6.32-wiregate-1.31 ohci_hcd
Jun 24 00:01:07 wiregate312 kernel: [ 7.960914] usb usb1: SerialNumber: 0000:00:0f.4
Jun 24 00:01:07 wiregate312 kernel: [ 7.968173] usb usb1: configuration #1 chosen from 1 choice
Jun 24 00:01:07 wiregate312 kernel: [ 7.975201] hub 1-0:1.0: USB hub found
Jun 24 00:01:07 wiregate312 kernel: [ 7.981947] hub 1-0:1.0: 4 ports detected
Jun 24 00:01:07 wiregate312 kernel: [ 7.992235] ehci_hcd 0000:00:0f.5: PCI INT D -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
Jun 24 00:01:07 wiregate312 kernel: [ 8.005428] ehci_hcd 0000:00:0f.5: EHCI Host Controller
Jun 24 00:01:07 wiregate312 kernel: [ 8.011961] ehci_hcd 0000:00:0f.5: new USB bus registered, assigned bus number 2
Jun 24 00:01:07 wiregate312 kernel: [ 8.336169] ehci_hcd 0000:00:0f.5: irq 11, io mem 0xefffd000
Jun 24 00:01:07 wiregate312 kernel: [ 8.364066] usb 1-4: new full speed USB device using ohci_hcd and address 2
Jun 24 00:01:07 wiregate312 kernel: [ 8.452123] ehci_hcd 0000:00:0f.5: USB 2.0 started, EHCI 1.00
Jun 24 00:01:07 wiregate312 kernel: [ 8.459062] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
Jun 24 00:01:07 wiregate312 kernel: [ 8.465898] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 24 00:01:07 wiregate312 kernel: [ 8.479203] usb usb2: Product: EHCI Host Controller
Jun 24 00:01:07 wiregate312 kernel: [ 8.485847] usb usb2: Manufacturer: Linux 2.6.32-wiregate-1.31 ehci_hcd
Jun 24 00:01:07 wiregate312 kernel: [ 8.492484] usb usb2: SerialNumber: 0000:00:0f.5
Jun 24 00:01:07 wiregate312 kernel: [ 8.499405] usb usb2: configuration #1 chosen from 1 choice
Jun 24 00:01:07 wiregate312 kernel: [ 8.506119] hub 2-0:1.0: USB hub found
Jun 24 00:01:07 wiregate312 kernel: [ 8.512528] hub 2-0:1.0: 4 ports detected
Jun 24 00:01:07 wiregate312 kernel: [ 8.875351] Uniform Multi-Platform E-IDE driver
Jun 24 00:01:07 wiregate312 kernel: [ 9.151225] amd74xx 0000:00:0f.2: UDMA100 controller
Jun 24 00:01:07 wiregate312 kernel: [ 9.157500] amd74xx 0000:00:0f.2: IDE controller (0x1022:0x209a rev 0x01)
Jun 24 00:01:07 wiregate312 kernel: [ 9.163826] amd74xx 0000:00:0f.2: IDE port disabled
Jun 24 00:01:07 wiregate312 kernel: [ 9.170041] amd74xx 0000:00:0f.2: not 100% native mode: will probe irqs later
Jun 24 00:01:07 wiregate312 kernel: [ 9.176164] ide0: BM-DMA at 0xff00-0xff07
Jun 24 00:01:07 wiregate312 kernel: [ 9.244069] usb 1-4: new full speed USB device using ohci_hcd and address 3
Jun 24 00:01:07 wiregate312 kernel: [ 9.454795] usb 1-4: New USB device found, idVendor=067b, idProduct=2303
Jun 24 00:01:07 wiregate312 kernel: [ 9.461030] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jun 24 00:01:07 wiregate312 kernel: [ 9.467283] usb 1-4: Product: USB-Serial Controller D
Jun 24 00:01:07 wiregate312 kernel: [ 9.473483] usb 1-4: Manufacturer: Prolific Technology Inc.
Jun 24 00:01:07 wiregate312 kernel: [ 9.480136] usb 1-4: configuration #1 chosen from 1 choice
Jun 24 00:01:07 wiregate312 kernel: [ 9.486509] hda: TRANSCEND, CFA DISK drive
Jun 24 00:01:07 wiregate312 kernel: [ 10.164392] hda: host side 80-wire cable detection failed, limiting max speed to UDMA33
Jun 24 00:01:07 wiregate312 kernel: [ 10.176677] hda: UDMA/33 mode selected
Jun 24 00:01:07 wiregate312 kernel: [ 10.183047] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Jun 24 00:01:07 wiregate312 kernel: [ 10.360114] ide-gd driver 1.18
Jun 24 00:01:07 wiregate312 kernel: [ 10.366111] hda: max request size: 128KiB
Jun 24 00:01:07 wiregate312 kernel: [ 10.371868] hda: 7962192 sectors (4076 MB) w/1KiB Cache, CHS=7899/16/63
Jun 24 00:01:07 wiregate312 kernel: [ 10.377924] hda: hda1 hda2
Jun 24 00:01:07 wiregate312 kernel: [ 10.701487] device-mapper: uevent: version 1.0.3
Jun 24 00:01:07 wiregate312 kernel: [ 10.710212] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
Jun 24 00:01:07 wiregate312 kernel: [ 12.418391] udevd version 125 started
Jun 24 00:01:07 wiregate312 kernel: [ 15.552002] input: PC Speaker as /class/input/input0
Jun 24 00:01:07 wiregate312 kernel: [ 22.460810] usbcore: registered new interface driver usbserial
Jun 24 00:01:07 wiregate312 kernel: [ 22.466799] USB Serial support registered for generic
Jun 24 00:01:07 wiregate312 kernel: [ 22.472835] usbcore: registered new interface driver usbserial_generic
Jun 24 00:01:07 wiregate312 kernel: [ 22.478907] usbserial: USB Serial Driver core
Jun 24 00:01:07 wiregate312 kernel: [ 22.742695] AMD Geode RNG detected
Jun 24 00:01:07 wiregate312 kernel: [ 23.440319] USB Serial support registered for pl2303
Jun 24 00:01:07 wiregate312 kernel: [ 23.446434] pl2303 1-4:1.0: pl2303 converter detected
Jun 24 00:01:07 wiregate312 kernel: [ 23.727203] usb 1-4: pl2303 converter now attached to ttyUSB0
Jun 24 00:01:07 wiregate312 kernel: [ 23.733416] usbcore: registered new interface driver pl2303
Jun 24 00:01:07 wiregate312 kernel: [ 23.739415] pl2303: Prolific PL2303 USB to serial adaptor driver
Jun 24 00:01:07 wiregate312 kernel: [ 24.206938] Geode LX AES 0000:00:01.2: PCI INT A -> Link[LNKA] -> GSI 10 (level, low) -> IRQ 10
und hier noch ein paar Auszüge aus der Kommandozeile...
root@wiregatexxx:~# ls -l /dev/usbserial-1-4
lrwxrwxrwx 1 root root 7 24. Jun 23:55 /dev/usbserial-1-4 -> ttyUSB0
root@wiregatexxx:~# lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 007: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
root@wiregatexxx:~# udevadm info -a -n /dev/ttyUSB0 | grep '{serial}' | head -n1
ATTRS{serial}=="0000:00:0f.4"
root@wiregatexxx:~#
root@wiregatexxx:~# ls -l /dev/KWL
ls: Zugriff auf /dev/KWL nicht möglich: Datei oder Verzeichnis nicht gefunden
Auch ein Neustart brachte keinen Erfolg...
Bin mit meinem Latein echt am Ende und hoffe das ihr einen Tip für mich habt woran es liegen könnte...
cu Yfkt5A
DALI(ABB DG/S1.1), KODI Odroid, TrueNAS, Zehnder ComfoAir 200 L Luxe
microk8s-Cluster: HomeAssistant, MusicAssistant, mosquitto, TVHeadend, jellyfin
Also ich habe hier 3 verschiedene pl2303 und keiner davon hat (im Gegensatz zu den meisten FTDIs) eine serial number. Da kann man dann halt nur über die Bus-ID arbeiten :-(
hab das EEPROM jetzt in der Arbeit auf einer VM WinXP beschrieben, scheint funktioniert zu haben, testen kann ich allerdings erst zu hause und vermutlich komm ich heute nicht dazu.
Für alle die dasselbe Prob haben:
Vorher musste ich noch einen Treiber installieren, den ich von hier runtergeladen habe...
cu Yfkt5A
