Hi.
I need help programming my alarm system
I bought a Gira KNX alarm system but not only I am starting with KNX but unfortunately it also has no english instruction or english software. I have to rely on online translators which are a bit...err... dubious.
I have many questions and don't know even where to start but here goes:
1 - My house has basement, ground floor and upper floor. So, I would like to have 3 options: fully armed (when away), basement armed, basement and ground floor armed (when sleeping). Which option should I choose?
1x Innenraum, 1x Außenhaut (verschachtelt)
2x [1 x Innenraum, 1x Außenhaut (verschachtelt)]
bis zu 4 unabhängige Bereiche
bis zu 4 abhängige Bereiche (kaskadiert)
2 - I will be using 2 types of presence/movement sensors: KNX and 230v (connected to a KNX push sensor). Both in normal operation only trigger when lux level is below a certain value. How will they perform as alarm sensors? Will they only trigger below that same lux level?
3 - Does this alarm have any option set the time delay before alarm goes off? For example, I want to enter the house and have x seconds to disarm the alarm before it starts to shout. Can I do this?
4- I also have the Gira 0900 00 Telefonwählgerät AWUG. I bought this one online (used) but it came with no software or cable to program. Is it a regular rs232 cable or does it have special pinout? Also, where can I get the programming software?
5 - Does the Telefonwählgerät AWUG offer the ability to arm/disarm the alarm remotely?
If someone can help... I would be thankful
Thanks.
Thanks.
