Dann werde ich morgen mal anfangen den anderen Daemon dahin gehend umzubauen, die Damon config daraus zu stricken und dann die RRD einzubauen.
Danke und Gruß
Danke und Gruß
get mv at_temp get mv at_stat
get ci holiday_period start1 get ci holiday_period start2 get ci holiday_period end1 get ci holiday_period end2
set ci holiday_period ....
root@wiregate907:/etc/ebusd# perl telnet.pl Unquoted string "cfg" may clash with future reserved word at telnet.pl line 14. Unquoted string "cfg" may clash with future reserved word at telnet.pl line 34. get ci hydraulic 4 get ci language error send ebus msg get ci holiday_period 11.01.2013 error start2 ==> 01 01 ff 24.01.2013 error end2 ==> 01 01 ff get ci holiday_cir2_temp 20.0000 get ci password error send ebus msg get ci cir2_set_temp 35.0000 get ci cir2_flow_temp 37.9375 get ci hw_heat_time 20.00
und mit quit
... get cir2 rt_day 28.00 set cir2 rt_day 30.00 ACK get cir2 rt_day 30.00 ...
.GA;DPT;RRD_TYPE;RRD_STEP;set;ci language;Sprachvariante GA;DPT;RRD_TYPE;RRD_STEP;set;ci holiday_period start1;Ferienzeitraum GA;DPT;RRD_TYPE;RRD_STEP;set;ci holiday_period start2;Ferienzeitraum GA;DPT;RRD_TYPE;RRD_STEP;set;ci holiday_period end1;Ferienzeitraum GA;DPT;RRD_TYPE;RRD_STEP;set;ci holiday_period end2;Ferienzeitraum GA;DPT;RRD_TYPE;RRD_STEP;set;ci password pin1;Passwort Konfiguration GA;DPT;RRD_TYPE;RRD_STEP;set;ci password pin2;Passwort Konfiguration GA;DPT;RRD_TYPE;RRD_STEP;set;ci password pin3;Passwort Konfiguration GA;DPT;RRD_TYPE;RRD_STEP;set;ci password pin4;Passwort Konfiguration GA;DPT;RRD_TYPE;RRD_STEP;set;ci hw_wait_time;WW-Zeit max. bei Heizanforderung GA;DPT;RRD_TYPE;RRD_STEP;set;ci pre_off_time;Vorabschaltzeit (Minuten) GA;DPT;RRD_TYPE;RRD_STEP;set;ci freeze_wait;Frostschutz-Verzögerung (Stunden) GA;DPT;RRD_TYPE;RRD_STEP;set;ci temp_error;Temperaturfehlererkennung GA;DPT;RRD_TYPE;RRD_STEP;set;ci boiler;Pufferspeicher vorhanden GA;DPT;RRD_TYPE;RRD_STEP;set;ci hw_heat_time;Heizzeit max. bei WW-Anforderung GA;DPT;RRD_TYPE;RRD_STEP;set;amu zh_bivalent;Zusatzheizung - Bivalenzpunkt GA;DPT;RRD_TYPE;RRD_STEP;set;amu zh_hysterese;Zusatzheizung/ Hysterese GA;DPT;RRD_TYPE;RRD_STEP;set;amu zh_hys_delay;Zusatzheizung/ Verzögerung Hysterese GA;DPT;RRD_TYPE;RRD_STEP;set;amu zh_heating;Zusatzheizung/ Heizung GA;DPT;RRD_TYPE;RRD_STEP;set;amu zh_water;Zusatzheizung/ WarmWasser
~/src/ebusd/tools $ ./csv -h Usage: csv [OPTION] cfgdir -a --all print ALL -c --cyc print CYC -d --detail print DETAIL -g --get print GET -s --set print SET -h --help print this message. ~/src/ebusd/tools $ ./csv ../../csv/. -dc 2013-02-17 14:54:39.016 [0x02 NOT] ../../csv/./vaillant_cyc.csv 2013-02-17 14:54:39.017 [0x02 NOT] ../../csv/./vaillant_cyc.csv success 2013-02-17 14:54:39.017 [0x02 NOT] ../../csv/./vaillant_get.csv 2013-02-17 14:54:39.017 [0x02 NOT] ../../csv/./vaillant_get.csv success 2013-02-17 14:54:39.017 [0x02 NOT] ../../csv/./vaillant_set.csv 2013-02-17 14:54:39.018 [0x02 NOT] ../../csv/./vaillant_set.csv success 2013-02-17 14:54:39.018 [0x01 INF] [000] cyc : broad.date_time_temp (type: 1) FE0700 (len: 9) [4] ==> Datum, Uhrzeit und Aussentempertur 2013-02-17 14:54:39.018 [0x01 INF] temp pos: 1,2 d2b [ 1.00] [°C] - Temperatur 2013-02-17 14:54:39.018 [0x01 INF] day pos: 8 bdy [ 0.00] [-] - Wochentag 2013-02-17 14:54:39.018 [0x01 INF] date pos: 6,7,9 bda [ 0.00] [-] - Datum 2013-02-17 14:54:39.018 [0x01 INF] time pos: 5,4,3 bti [ 0.00] [-] - Uhrzeit 2013-02-17 14:54:39.018 [0x01 INF] 2013-02-17 14:54:39.018 [0x01 INF] [001] cyc : broad.load_VF_temp (type: 1) FEB50527 (len: 4) [2] ==> Speicherladung und Vorlauftempertur 2013-02-17 14:54:39.018 [0x01 INF] load pos: 2 bcd [ 1.00] [-] 00,01 Speicherladung 2013-02-17 14:54:39.018 [0x01 INF] temp pos: 3 d1c [ 1.00] [°C] - Vorlauftemperatur 2013-02-17 14:54:39.018 [0x01 INF] 2013-02-17 14:54:39.018 [0x01 INF] [002] cyc : broad.date_time (type: 1) FEB51600 (len: 8) [3] ==> Datum, Uhrzeit 2013-02-17 14:54:39.018 [0x01 INF] day pos: 7 hdy [ 0.00] [-] - Wochentag 2013-02-17 14:54:39.018 [0x01 INF] date pos: 5,6,8 bda [ 0.00] [-] - Datum 2013-02-17 14:54:39.018 [0x01 INF] time pos: 4,3,2 bti [ 0.00] [-] - Uhrzeit 2013-02-17 14:54:39.018 [0x01 INF] 2013-02-17 14:54:39.018 [0x01 INF] [003] cyc : broad.temp (type: 1) FEB51601 (len: 3) [1] ==> Aussentemperatur 2013-02-17 14:54:39.018 [0x01 INF] temp pos: 2,3 d2b [ 1.00] [°C] - Temperatur 2013-02-17 14:54:39.018 [0x01 INF]
2013-02-17 14:37:36.333 [0x20 EBH] 10 fe b5 05 04 27 00 1a 00 15 2013-02-17 14:37:36.333 [0x40 EBS] 0 13.00 2013-02-17 14:37:39.907 [0x20 EBH] 10 fe b5 16 08 00 04 37 14 17 02 07 13 0c 2013-02-17 14:37:39.907 [0x40 EBS] Sun 17.02.2013 14:37:04 2013-02-17 14:37:40.348 [0x20 EBH] 10 fe b5 16 03 01 60 05 75 2013-02-17 14:37:40.348 [0x40 EBS] 5.375 2013-02-17 14:37:40.902 [0x20 EBH] 10 fe 07 00 09 60 05 04 37 14 17 02 06 13 a1 2013-02-17 14:37:40.902 [0x40 EBS] 5.375 Sun 17.02.2013 14:37:04
