Gira Türkommunikations-System
    Zitat von MikeMelga Beitrag anzeigen
    Is that so? That means every time I see a single keyless-in product in a 1-fach box I know that is working via the internal relais and that is not very secure.
    Yes, it is so.
    Security is only possible with communication via coupler, and the best solution is to have the coupler inside and the keyless in device on the outside.
      Zitat von MatthiasS Beitrag anzeigen
      Yes, it is so.
      That is really bad.
      I guess I'll have to extend that 6 pin patch via a regular cat5e to the inside and connect it to the bus coupler
      Hope it works.
      Thanks MatthiasS
        Hope it works.
        It will I tried this with a 2 m - connection.
          I will need at least a 20m connection
          Fingers crossed.
            So as I understand
            I must have a double frame with a bus coplerem and Keypad. The keypad is connected to a bus coupler with 6-pin cable. A bus coupler can be attached to such information module. Yes.
