Theben dimmer - can someone explain "MIX" vs "FIX"?
    So I have a few Theben dimmers, but I believe they are all FIX models. I have DM8-2T, DM4T and DM4-2T
    What is the difference with the DME / DMG models?
    I think it's something to do with FIX vs MIX. I have read that MIX gives greater flexibility to mix and match modules.
    But what flexibility would I need? The FIX dimmers I have allow each output to be set to a given load type. Why would I want something more flexible than that?
    I am just trying to understand the product lines. Thanks
    FIX: No additional Modules possible.
    MIX: You can put an Dimmer-Extension beside a Switch-Basicmodule or Shutter-Basic-Module. As the name says: You can mix up to 3 Modules (Dimming, Switching, Binary Input, Shutter,...).
    You always need the Basic (for example DMG) and up to 2 extensions (DME,JME...)
    This reduces the phys. adresses...
