Could I get an ETS product catalog?
    Hello everyone,
    I am a system integration engineer currently working on a KNX lighting control project. I am trying to configure an old Altenburger dimmer, but unfortunately, the manufacturer is no longer in business, and I cannot find the required ETS application program anywhere online.
    Here are the specific details of the device:
    • Manufacturer: Altenburger Electronic GMBH
    • Product: ALTODIM 600-0/P (Phase-interval controlled push dimmer)
    • Type: IBDA600-0/P
    • Order-no.: 80.13.161
    • Hardware Applikation Version: V3.0 (Crucial!)
    I managed to find an old 2009 Altenburger database archive, but it only contains version 2.2 for this specific order number. When I tried to force download V2.2 to the device, I received a "BCU Mask version mismatch" error. This means the internal communication chip has physically changed in the V3.0 hardware, and I absolutely need the V3.0 database file (.vd, .vd4, .vd5, or .knxprod) to proceed.
    If anyone happens to have this specific V3.0 file saved in their personal archive or old project backups, I would immensely appreciate it if you could share it with me.
    Thank you in advance for your time and support!
  • Als Antwort markiert von chkmegg am 16.04.2026, 09:35.
    it was posted here just a few days ago.
    https://knx-user-forum.de/forum/%C3%...bdas-80-14-120
    ETS_3_09_2012.vd3 in the zip-file contains what you are looking for.
    Best regards, Kilian
        I love you
          Es wird ausdrücklich die ETS-Anwendung V3.0 oder das werkseitige KNX-Archiv des Herstellers benötigt.
          Wenn diese in den offiziellen ETS-Datenbanken nicht vorhanden sind, lässt sich das Gerät über ETS nicht ordnungsgemäß programmieren. Genauso wie in https://zotabetcasino-au.com/​ Online-Casinos die Funktionsfähigkeit und Verfügbarkeit der Funktionen von der jeweiligen Plattform und ihrer softwaretechnischen Umsetzung abhängen, hängt in KNX-Systemen alles vom Vorhandensein korrekter Bibliotheken und kompatibler Komponenten ab. Fehlen grundlegende Elemente oder werden sie nicht unterstützt, lässt sich die Konfiguration mit keiner „Workaround-Lösung“ korrekt durchführen – das System funktioniert dann einfach nicht wie vorgesehen.
          Zuletzt geändert von Trostium; 29.05.2026, 10:36.
            Wie bitte?
            QC-Client, HS-Logikbausteine
