I'm extending our current KNX installation with a second line. I will have two lines (1.1.x and 1.2.x) which are set up as followed:
- main line: power module
- line 1.1.x: line coupler + power module + KNX members + IP interface
- line 1.2.x: line coupler + power module + KNX members
From the IP interface running on line 1.1.x I can program addresses and applications from ETS3 running on line 1.2.x.
However, when I try to send a group address from ETS3 to a KNX member on line 1.2.x, I'm getting the error "Het telegram werd op de bus niet bevestigd". The light is also not switched on.
Google translation: "Das Telegramm auf den Bus wurde nicht bestätigt".
What am I doing wrong?
Tx - Ivan
Tx - Ivan
