GIRA HS logic for programmable week thermostat
    hello,
    as i didn't find any posts/threads about temperature control I would like to kindly ask you:
    > Is there any baustein or any other way how to program desired temperatures in controlled rooms through days/week? I would like it to be user-programmable through HS-client (touch panel respectively).
    To make myself clear I would like to set the temperature in bedroom for example to e.g. 23 degC on Monday from 8-12.00, from 12-16.00 to 20 degC and in the evening back to 23, while at night to 19 degC. And so on for other days...
    > If no, how can I work with fields and/or matrices using minimum bausteins, not 3 or 4 bausteins for every variable that could be an element of some matrix.
    Thanks a lot. Your help would be very appreciated!
    -korst (still a newbie to eib)
    Hi korst,
    of course there is a way with HS. And it is quite easy.
    HS comes with an infinte number of so called "Universal switching clock" - UZSU.
    All you have to do is:
    • create a new UZSU. I have one for every room.
    • add at least four commands:
      set room object to 1 (comfort)
      set room object to 2 (standby)
      set room object to 3 (night)
      set room object to 4 (frost)
    • in your regulator device you will have to define three different temperatures for 1 to 3
    • now you can open your new uszu in HS visu an add switching points as you like
      hi Matthias,
      thanks very much for answer, I've just made it working right. Still I have the question if there is any baustein that allow us to work with matrices.
      Many thanks again, have a pleasant weekend
      regards, korst
        Matrices?
        What do you want to do?
          Thanks for answer, but after detailed study of UZSU I found out it is the best solution also for my problem of matrices. My apologies
          korst
            Ok, fine :-)
            If you want to try doing your matrix by logic modules, have a look at:
            http://www.dacom-homeautomation.de/d...?id=111&s=info
            Docu:
            http://www.dacom-homeautomation.de/c...planmatrix.pdf
