hello,
as i didn't find any posts/threads about temperature control I would like to kindly ask you:
> Is there any baustein or any other way how to program desired temperatures in controlled rooms through days/week? I would like it to be user-programmable through HS-client (touch panel respectively).
To make myself clear I would like to set the temperature in bedroom for example to e.g. 23 degC on Monday from 8-12.00, from 12-16.00 to 20 degC and in the evening back to 23, while at night to 19 degC. And so on for other days...
> If no, how can I work with fields and/or matrices using minimum bausteins, not 3 or 4 bausteins for every variable that could be an element of some matrix.
Thanks a lot. Your help would be very appreciated!
-korst (still a newbie to eib)
