HS Expert 2.6->2.7->2.8 migration ERROR
    HS/FS HS Expert 2.6->2.7->2.8 migration ERROR
    Hello,
    I've been using HSE 2.6 for long time now and tried to migrate to 2.7 and then to 2.8.
    I archived project in 2.6 and imported it in 2.7.
    When trying to transfer it to HomeServer3 I get QC config error:
    an error occured while reading in the project.xml
    log file looks like this:
    Fehler beim Einlesen der project.xml [C:\moje dokumenty\dom\gira\HS+FS Experte 2.7\Projects\migracja_hs26-MASTER\migracja_hs26-MASTER\quadconfig\project.xml]: System.NullReferenceException: Object reference not set to an instance of an object.
    at Quadconverter.CReader.readProject(String _filename)
    anyone can assist?
    thank you
    Hello,
    I migrated last week directly from 2.6 to 2.8 and I had a similar error. Try to change something in the quadclient, perhaps that alone could fix it.
    Regards
    Christian
      thank you for assistance - it is the solution
      i should be more open minded when i see errors
      regards
