Ich hab da auch was am Start, in Zeiten von aufgezwungenen SMS-Flatrates ist das nämlich auch wurscht
Und zusammen mit NFC kann es durchaus Smart werden aber da ist jetzt Zeit fürn neuen Thread - ab 13.11.
Und zwar werden die SMSen irgendwie nicht zuverlässig versand.
Die landen zwar in checked, aber dann gehts nicht mehr weiter:
2012-12-12 01:11:04,6, GSM1: Initializing modem
2012-12-12 01:11:04,7, GSM1: -> ATZ
2012-12-12 01:11:04,7, GSM1: Command is sent, waiting for the answer
2012-12-12 01:11:04,7, GSM1: <- OK
2012-12-12 01:11:05,7, GSM1: -> AT+CSQ
2012-12-12 01:11:05,7, GSM1: Command is sent, waiting for the answer
2012-12-12 01:11:05,7, GSM1: <- +CSQ: 6,0 OK
2012-12-12 01:11:05,6, GSM1: Signal Strength Indicator: (6,0) -101 dBm, Bit Error Rate: less than 0.2 %
2012-12-12 01:11:05,6, GSM1: Checking if Modem is registered to the network
2012-12-12 01:11:05,7, GSM1: -> AT+CREG?
2012-12-12 01:11:05,7, GSM1: <- +CREG: 0,1 OK
2012-12-12 01:11:05,6, GSM1: Modem is registered to the network
2012-12-12 01:11:05,6, GSM1: Selecting PDU mode
2012-12-12 01:11:06,7, GSM1: -> AT+CMGF=0
2012-12-12 01:11:06,7, GSM1: Command is sent, waiting for the answer
2012-12-12 01:11:06,7, GSM1: <- OK
2012-12-12 01:11:06,6, GSM1: Checking memory size
2012-12-12 01:11:06,7, GSM1: -> AT+CPMS?
2012-12-12 01:11:07,7, GSM1: <- +CPMS: "ME",0,25,"ME",0,25,"MT",2,45 OK
2012-12-12 01:11:07,6, GSM1: Used memory is 0 of 25
2012-12-12 01:11:07,6, GSM1: No SMS received
2012-12-12 01:11:17,6, GSM1: Checking device for incoming SMS
2012-12-12 01:11:17,6, GSM1: Checking if modem is ready
2012-12-12 01:11:17,7, GSM1: -> AT
2012-12-12 01:11:17,7, GSM1: Command is sent, waiting for the answer
2012-12-12 01:11:17,7, GSM1: <- OK
2012-12-12 01:11:17,6, GSM1: Pre-initializing modem
2012-12-12 01:11:17,7, GSM1: -> ATE0+CMEE=1
2012-12-12 01:11:18,7, GSM1: <- OK
2012-12-12 01:11:18,6, GSM1: Checking if modem needs PIN
2012-12-12 01:11:18,7, GSM1: -> AT+CPIN?
2012-12-12 01:11:18,7, GSM1: Command is sent, waiting for the answer
2012-12-12 01:11:18,7, GSM1: <- +CME ERROR: 772
2012-12-12 01:11:18,2, GSM1: PIN handling: expected READY, modem answered +CME ERROR: 772
2012-12-12 01:11:18,2, GSM1: Modem handler 0 terminated abnormally. PID: 24275.
2012-12-12 09:23:45,5, smsd: Moved file /var/spool/sms/outgoing/email_sms_gateway-2012-11-12-9-23-39-xxxxxxxxx to /var/spool/sms/checked
2012-12-12 09:26:06,5, smsd: Moved file /var/spool/sms/outgoing/email_sms_gateway-2012-11-12-9-25-53-xxxxxxxx to /var/spool/sms/checked
Konkret gehts um die letzten zwei.
root@wiregate402:/var/spool/sms# cat /etc/smsd.conf
# /etc/smsd.conf
# Description: Main configuration file for the smsd
devices = GSM1
outgoing = /var/spool/sms/outgoing
checked = /var/spool/sms/checked
incoming = /var/spool/sms/incoming
logfile = /var/log/smstools/smsd.log
infofile = /var/run/smstools/smsd.working
pidfile = /var/run/smstools/smsd.pid
failed = /var/spool/sms/failed
sent = /var/spool/sms/sent
stats = /var/log/smstools/smsd_stats
loglevel = 7
#delaytime = 10
#errorsleeptime = 10
#blocktime = 3600
#stats = /var/log/smsd_stats
#stats_interval = 3600
#stats_no_zeroes = no
#checkhandler = /usr/local/bin/smscheck
receive_before_send = no
# autosplit 0=no 1=yes 2=with text numbers 3=concatenated
autosplit = 3
# store_received_pdu 0=no, 1=unsupported, 2=unsupported and 8bit, 3=all
#store_received_pdu = 1
#validity = 255
#decode_unicode_text = no
#internal_combine = no
# You can specify here an external program that is started whenever an alarm occurs.
# alarmhandler = /path/to/an/alarmhandler/script
# Specifies what levels start an alarmhandler. You can use value between 2 and 5.
# alarmlevel = 4
# eventhandler = @EVENTHANDLER@
#blacklist = /etc/smstools/blacklist
#whitelist = /etc/smstools/whitelist
#regular_run_cmd = AT+CUSD=1,"*100#",0;
#regular_run_interval = 60
#regular_run_logfile = /var/log/sms/smsd_regular_run.log
#regular_run_cmd = AT+CUSD=1,"*100#",15;
#regular_run_statfile = /var/log/sms/sms_guthaben
#[queues]
# Commented lines are examples for germany
# D1 = /var/spool/sms/D1
# D2 = /var/spool/sms/D2
# O2 = /var/spool/sms/O2
# EPLUS = /var/spool/sms/EPLUS
# QUAM = /var/sppol/sms/QUAM
# MOBILCOM = /var/spool/sms/MOBILCOM
#OTHER = /var/spool/sms/OTHER
#[provider]
# D1 = 49160, 49170, 49171, 49175, 49151
# D2 = 491520, 49162, 49172, 49173, 49174
# O2 = 49176, 49179, 49159
# EPLUS = 49163, 49177, 49178, 49157
# QUAM = 49150
# MOBILCOM = 49156
#OTHER = 0,1,2,3,4,5,6,7,8,9
#[GSM1]
# init = ATE0+CPMS="SM"+CNMI=2,0,0,2,1
# # Windows: /dev/com1, Solaris: /dev/cua/a, Linux /dev/ttyS0
# device = /dev/ttyS0
# incoming = yes
# queues = OTHER
# You don't need a PIN for mobile phones
# pin = xxx
# mode = new
# smsc = xxxxx
# baudrate = 19200
# rtscts = yes
# cs_convert = yes
# report = no
# memory_start = 1
# primary_memory = memory name
# secondary_memory = memory name
# secondary_memory_max = number
# pdu_from_file = /var/spool/sms/GSM1-PDU
# sending_disabled = no
# decode_unicode_text = no
# internal_combine = no
#[GSM2]
#init = ATE0
# Windows: /dev/com2, Solaris: /dev/cua/b, Linux /dev/ttyS1
#device = /dev/ttyS1
#incoming = yes
#queues = OTHER
#You don't need a PIN for mobile phones
#pin = xxx
#mode = new
#smsc = xxxx
#baudrate = 19200
#rtscts = yes
#cs_convert = yes
#report = no
#memory_start = 1
#primary_memory = memory name
#secondary_memory = memory name
#secondary_memory_max = number
#pdu_from_file = /var/spool/sms/GSM2-PDU
#sending_disabled = no
[GSM1]
init=ATZ
#init2 = AT+CUSD=1,"*101#",0
device = /dev/ttyS0
incoming = yes
cs_convert=yes
pin = xxxx
report=no
baudrate = 115200
rtscts = no
Mir kommts so vor als wenn smstools sich verabschiedet nach ner Zeit, denn wenn ich smstools restart gehts wieder, zumindest für ne gewisse Zeit, wie lang die ist weiß ich noch nicht.
Das Plugin schiebt die Dateien auch brav in outgoing Ordner, und dann in checked, aber versendet werden sie dann meistens nicht, eben nur wenn man smstools neu startet.
Klar ich kann jetzt alle 10min smstool neustarten, aber das kann ja nicht die Lösung sein.
So sind se halt die Huaweis
Welches ist das genau ? für die Suche..
Wir haben z.B. ein Problem mit einem "richtigen" Falcom Tango - seit einem Austausch der SIM-Karte alle paar Wochen:
Tango: PIN handling: expected READY, modem answered +CME ERROR: 13, SIM failure
Da ist in SW nichts zu fixen, das braucht dann nen Power-cycle.. Das Ding lief aber vorher mind. 8 Jahre am Stück 24x7..
Insofern bin ich durchaus - trotz der Präferenz zu "meine HW" dazu aufgeschlossen: https://knx-user-forum.de/wiregate/1...eway-3.html#22
Wie gesagt is nen "Siemens / MC Technologies TC65 Java Terminal GSM"
Ansonsten super Teil, hat auch im Keller mit seiner guten Antenne noch Empfang wo sonst NICHTS Empfang hat.
Sieht man ja im Log.
Naja ich will lieber SMS direkt versenden, nicht erst über den Umweg Internet.
Und die Kiste hat mich auf eBay grad mal 10€ gekostet (+10€ Versand aus Ösi-Land ... )
Vor allem haben manche SMS Dienste auch ne Länderbeschränkung und weiß nich was, und da wir in direkter Nähe zur Schweiz wohnen sind wir auch dementsprechend oft dort und da möchte ich schon dass es wirklich funktioniert
Und wenns jetzt funktioniert bin ich wunschlos glücklich.
Such nurnoch nach Ideen was man aus der Ferne per SMS was steuern könnte, aber Sicher muss es auch sein.
EDIT: Zu deim Problem, hast du dir mal AT-Command-List für deine Kiste angeschaut, für mich hört sich das nach iwas mit der Pin an, schalt doch mal die Pinabfrage aus, oder ein, je nach dem
