Hoi
WG316 VPN ist offen. Villeicht kann mal jemand kurz drüber schauen bitte.
Beim Update gestern Abend um 20:45 auf PL 34
ist der OWServer abgeflogen und er lässt sich im Webmin nicht mehr aktivieren.
Beim Update ist der mpd nicht durch gelaufen. Wohl wegen meiner früheren Versuche damit.
Reading package lists... Building dependency tree... Reading state information... The following packages have been kept back: libao-dev The following packages will be upgraded: mpd webmin-wiregate wg-patch wiregated 4 upgraded, 0 newly installed, 0 to remove and 1 not upgraded. Need to get 1786kB of archives. After this operation, 45.1kB of additional disk space will be used. Get:1 http://repo.wiregate.de wiregate-0.1/main webmin-wiregate 0.3-69 [1517kB] Get:2 http://repo.wiregate.de wiregate-0.1/main wiregated 0.9-68 [39.5kB] Get:3 http://repo.wiregate.de wiregate-0.1/main wg-patch 0.0.34-5 [21.6kB] Get:4 http://repo.wiregate.de wiregate-0.1/main mpd 0.16.7-2~bpo50+3 [208kB] debconf: unable to initialize frontend: Dialog debconf: (TERM is not set, so the dialog frontend is not usable.) debconf: falling back to frontend: Readline debconf: unable to initialize frontend: Readline debconf: (This frontend requires a controlling tty.) debconf: falling back to frontend: Teletype dpkg-preconfigure: unable to re-open stdin: Fetched 1786kB in 1s (995kB/s) (Reading database ... 71653 files and directories currently installed.) Preparing to replace webmin-wiregate 0.3-65 (using .../webmin-wiregate_0.3-69_all.deb) ... Unpacking replacement webmin-wiregate ... Preparing to replace wiregated 0.9-65 (using .../wiregated_0.9-68_all.deb) ... Unpacking replacement wiregated ... Preparing to replace wg-patch 0.0.33-1 (using .../wg-patch_0.0.34-5_all.deb) ... Unpacking replacement wg-patch ... Preparing to replace mpd 0.15.12-1.1 (using .../mpd_0.16.7-2~bpo50+3_i386.deb) ... Unpacking replacement mpd ... Processing triggers for man-db ... Setting up webmin-wiregate (0.3-69) ... Setting up mpd (0.16.7-2~bpo50+3) ... Configuration file `/etc/mpd.conf' ==> Modified (by you or by a script) since installation. ==> Package distributor has shipped an updated version. ==> Keeping old config file as default. Installing new version of config file /etc/init.d/mpd ... Stopping Music Player Daemon: mpd. Starting Music Player Daemon: mpdunrecognized parameter in config file at line 5: error_file failed! invoke-rc.d: initscript mpd, action "restart" failed. dpkg: error processing mpd (--configure): subprocess post-installation script returned error exit status 1 Setting up wg-patch (0.0.34-5) ... Reinitializing monit daemon monit: No daemon process found Reloading exim4 configuration files: exim4. Stopping daemon monitor: monit. Starting daemon monitor: monit. Setting up wiregated (0.9-68) ... *** Restarting WireGate daemon wiregated *** Starting WireGate daemon: wiregated . *** Restarting WireGate 1-Wire daemon wiregated-ow *** Starting WireGate 1-Wire daemon: wiregated-ow . Reinitializing monit daemon Errors were encountered while processing: mpd E: Sub-process /usr/bin/dpkg returned an error code (1)
