Going mad with EIBD
    Going mad with EIBD
    Hi.
    I've spent the last 3 or 4 days trying to connect my Gira HS to my KNX installation without success.
    My KNX IP interface does not support routing (only tunneling) so I am using eibd.
    The problem is that I am very new to this and don't know exactly how to use eibd. Searching for online english (or even german) tutorials was a very frustrating task
    If anyone can help...I would be thankful.
    My setup is this:
    Gira HS3 - 192.168.0.22
    KNX IP Gateway (Weinzierl BAOS 770) - 192.168.0.20
    Computer running EIBD (Windows) - 192.168.0.12
    -What parameters should I use to start EIBD?
    -What IP should I use in them: the KNX IP interface or the computer running EIBD?
    -What IP should I put in the IP Gateway field of the Gira Expert software? The multicast IP or the eibd IP?
    Besides the eibnetdiscovery command, how can I test eibd for KNX connection?
    Thanks in advance.
    Regards,
    Mike
    i start my Eibd like this:
    eibd -d -i -c -D -S -T -R ipt:IP of the IP Gateway
    Multicast IP
    Moe
    Gruß Mike
      Hello Mike,
      A good idea for test purpose is skipping the Deamon-Parameter (I believe, this is the '-d' Option).
      The result is, that you get all the messages of 'eibd' in the console you started eibd.
      This helped me a lot to get the eibd running.
      HTH!
      Ciao
      Olaf
      Nichts ist so gerecht verteilt, wie der Verstand.
      Jeder meint, genug davon zu haben.
        Moe Hutz,
        Thanks! It worked! I've already tested that option but I thought it was wrong because eibnetsearch (included in eibd) always throws an error.
        We'll it's solved! Thanks again!
        dundee,
        Thanks. All the times I've tried eibd I always started without the daemon option but I didn't get any errors or messages. The only one showing was the warning not to run as root.
        Problem solved. Topic dead. Thanks.
          Well...it seems I've spoken too early
          EIBD is still driving me mad!
          Problem 1: I can get it to run on a XP machine. However on a Windows 7 machine I can only start it if I remove the server (-S) parameter. With -S I get this error:
          eibd -i -c -S -D -T -R -t256 ipt:192.168.0.20
          Layer 7(00000000,513F0DB8) EIBD should not run as root
          W00000001: EIBD should not run as root
          Layer 2(00BA1240,513F0DB8) Open
          Layer 0(00BA1438,513F0DB8) Open
          Layer 0(00BA1438,513F0DB8) Openend
          Layer 2(00BA1240,513F0DB8) Opened
          Layer 3(00BC1880,513F0DB8) Open
          Layer 8(00BA1518,513F0DB8) OpenInetSocket 6720
          Layer 8(00BA1518,513F0DB8) InetSocket opened
          Layer 8(00BE1C68,513F0DB8) Open
          Layer 0(00BE1CD8,513F0DB8) Open
          Layer 0(00BE1CD8,513F0DB8) Openend
          Layer 0(00BE1CD8,513F0DB8) Close
          Layer 1(00BA1438,513F0DB8) Send(020): 08 01 C0 A8 00 0A 0E 58 08 01 C0 A8 00 0A
          0E 58 04 04 02 00
          Layer 0(00BA1438,513F0DB8) Send(026): 06 10 02 05 00 1A 08 01 C0 A8 00 0A 0E 58
          08 01 C0 A8 00 0A 0E 58 04 04 02 00
          initilization of the EIBnet/IP server failed
          Problem 2: When I get eibd to run on the XP machine (with the server parameter) everything seems to be fine. I can use openremote. I can see the various bus telegrams however the Gira HS still doesn't read any knx value (like temperatures, counters) or works with any switch.
          How can I check for HS connectivity? I've attached a picture of the HS log. I can't tell from that if it is working or not
          Any help would be most welcome. Thanks.
            I've spent some more hours on this.
            Eibd still doesn't run on Windows 7.
            Eibd seems to run on XP. Gira's quad client can switch thing on/off and rise shutters but it can't read their status or any value. Is it possible that it can send telegrams to the bus but is unable to read them??
