Hi.
I've spent the last 3 or 4 days trying to connect my Gira HS to my KNX installation without success.
My KNX IP interface does not support routing (only tunneling) so I am using eibd.
The problem is that I am very new to this and don't know exactly how to use eibd. Searching for online english (or even german) tutorials was a very frustrating task
If anyone can help...I would be thankful.
My setup is this:
Gira HS3 - 192.168.0.22
KNX IP Gateway (Weinzierl BAOS 770) - 192.168.0.20
Computer running EIBD (Windows) - 192.168.0.12
-What parameters should I use to start EIBD?
-What IP should I use in them: the KNX IP interface or the computer running EIBD?
-What IP should I put in the IP Gateway field of the Gira Expert software? The multicast IP or the eibd IP?
Besides the eibnetdiscovery command, how can I test eibd for KNX connection?
Thanks in advance.
Regards,
Mike
My setup is this:
Thanks in advance.
Regards,
Mike
