eibd error on Windows 7
    KNX/EIB eibd error on Windows 7
    Hi.
    Everytime I start eibd on my windows 7 machine it throws this error:
    eibd -i -c -D -S -T -R ipt:192.168.0.20
    Layer 7(00000000,51960E8D) EIBD should not run as root
    W00000001: EIBD should not run as root
    Layer 2(00C51210,51960E8D) Open
    Layer 0(00C51408,51960E8D) Open
    Layer 0(00C51408,51960E8D) Openend
    Layer 2(00C51210,51960E8D) Opened
    Layer 3(00C71850,51960E8D) Open
    Layer 8(00C514E8,51960E8D) OpenInetSocket 6720
    Layer 8(00C514E8,51960E8D) InetSocket opened
    Layer 8(00C91C38,51960E8D) Open
    Layer 0(00C91CA8,51960E8D) Open
    Layer 0(00C91CA8,51960E8D) Openend
    Layer 0(00C91CA8,51960E8D) Close
    Layer 1(00C51408,51960E8D) Send(020): 08 01 C0 A8 00 0A 0E 58 08 01 C0 A8 00 0A
    0E 58 04 04 02 00
    Layer 0(00C51408,51960E8D) Send(026): 06 10 02 05 00 1A 08 01 C0 A8 00 0A 0E 58
    08 01 C0 A8 00 0A 0E 58 04 04 02 00
    initilization of the EIBnet/IP server failed
    However, if I remove the -S parameter... it works.
    On my XP machine it works even with the -S parameter.
    What can be wrong?
    Thanks.
    AW: eibd error on Windows 7
    I guess something with Windows 7 network settings.
    Check your firewall, anti vir, and network (homezone?) settings.
    Gesendet von meinem Nexus 7 mit Tapatalk 2
      En3rGy,
      Thanks for the suggestion but I already tried running EIBD with the firewall off and the AntiVirus disabled. Same error:
      Layer 7(00000000,519A50B7) EIBD should not run as root
      Layer 2(00CA1210,519A50B7) Open
      Layer 0(00CA1408,519A50B7) Open
      Layer 0(00CA1408,519A50B7) Openend
      Layer 2(00CA1210,519A50B7) Opened
      Layer 3(00CC1850,519A50B7) Open
      Layer 8(00CA14E8,519A50B7) OpenInetSocket 6720
      Layer 8(00CA14E8,519A50B7) InetSocket opened
      Layer 8(00CE1C38,519A50B7) Open
      Layer 0(00CE1CA8,519A50B7) Open
      Layer 0(00CE1CA8,519A50B7) Openend
      Layer 0(00CE1CA8,519A50B7) Close
      Layer 1(00CA1408,519A50B7) Send(020): 08 01 C0 A8 00 0A 0E 58 08 01 C0 A8 00 0A
      0E 58 04 04 02 00
      Layer 0(00CA1408,519A50B7) Send(026): 06 10 02 05 00 1A 08 01 C0 A8 00 0A 0E 58
      I don't understand what you mean with the network settings. The network is properly configured (I guess) as I have access to the KNX IP device for ETS programming.
      Any more suggestions?
        I have no clue, I'm just guessing.
        ETS works so it seems to be no network configuration problem. On the other hand, eibd is a server, listening on a specific port. Here might be a problem.
        Have you tried starting eibd as simple as possible, without the IP server option? Does a groupswrite work then?
          En3rGy,
          Thanks for the reply.
          I've tried to run EIBD as simple as possible. It works. I can do a groupswrite with success.
          The problem is the server parameter (-S). As soon as I set the -S parameter...it fails with 'initilization of the EIBnet/IP server failed'
          My network is ok, I'm starting it as administrator, no firewall problems.
          I've read other user with the same problems here in a 'eibd under windows' german topic.
          I have a Weinzierl IB BAOS 770 which does not support routing. I need eibd to allow it to receive connections from openremote, Gira HS and ETS. I guess I need the -S parameter for that, right?
          Also...should I start eibd with ipt:<ip of router> or iptn:<ip of router> ?
          Thanks.
            I have the same problem here. Tested on a W7 platform and BAOS 730.
            Any help is also appreciated!
            Thanks
              No one?
