How can I do this?
    KNX/EIB How can I do this?
    I have a Gira Led signal light 1171 00. It is basically an indicator light with two colors: red and green. They are both independently switchable.
    I am using this to see my alarm state (armed or disarmed). Although I don't have my alarm fully programmed I use this to check if my 'pseudo alarm' is on or off (the pseudo alarm is just a connection to openremote that triggers a phone call everytime the KNX sensors pick up movement).
    So... I've connected both color switches to a KNX actuator (one output per color).
    I toggle the 'alarm' on and off via two pushbuttons: one turns it on, the other turns it off. Then I have openremote switching off the other color.
    My problem is:
    I now want to turn the alarm on and off via a Gira keyless in keypad. For that, I need to make the toggle work properly.
    I already have the keyless in connected to a binary input but... how can I have it turn one light on and another off at the same time?
    I also have an ABB LMS1.1 logic module if it helps.
    Any suggestion?
    Thanks.
    Regards,
    Mike
    Configure one actuatorchannel as opener and one as closer. Trigger them withe the same GA.
      vento66,
      Thanks for your answer.
      You lost me there
      How can I do that?
        One is normaly closed... the Light is on.
        The other is normaly open... the Light is off.
        Whenn you trigger both a the same Time by the same GA, they will change their state.
        You can set this in the Actor Application in the ETS.
        Regards
          division,
          Got it! Thanks!
          Will try that.
          Thanks to you both.
          Regards,
          Mike
