Griesser MGX-9
    KNX/EIB Griesser MGX-9
    Hello,
    Sorry to post a message in English but my German is very limited...
    I have successfully installed and programmed "basic" MGX-9 functions to control sunblinds from Griesser. However, I don't manage to do the following:
    - Reuse local binary inputs (some of the commands are coming directly from the bus, and there are some binary inputs left over that I would like to re-use)
    - I don't manage to find status group objects, providing the position and orientation of a sunblind.
    That would be much appreciated if anyone with experience with MGX-9 programing could help me out with that...
    THanks in advance.
    Kind regards,
    Guillaume.
    Go to the parameters of the MGX-9, in the left above corner is a symbol you can click on to switch the parameters into the professionel mode.
    Then you can see all the settings you need.
      Thank you so much! THat's very helpful.
      Cheers.
