folgendes Problem bei meinem WG.
Das / Verzeichnis scheint permanent voll zu laufen. Die Logfiles werden gigantisch groß (mainlog.1 282 MB) paniclog.1 56MB). Ursache für die großen Logfiles sind wohl die permanenten Einträge, wie z.B. im syslog
Nov 5 09:20:41 wiregate723 monit[2644]: 'rootfs' inode usage 99.9% matches resource limit [inode usage>75.0%]
Nov 5 09:20:41 wiregate723 monit[2644]: 'rootfs' space usage 84.9% matches resource limit [space usage>80.0%]
Nov 5 09:20:41 wiregate723 monit[2644]: 'rescue_fs' inode usage 99.9% matches resource limit [inode usage>75.0%]
Nov 5 09:20:41 wiregate723 monit[2644]: 'owserver' PID has not changed
Nov 5 09:20:41 wiregate723 monit[2644]: 'lighttpd' process PID changed to 6054
Nov 5 09:20:54 wiregate723 OWFS[7124]: DEFAULT: ow_daemon.c
143) Entered background mode, quitting.
Nov 5 09:20:54 wiregate723 OWFS[7124]: DEFAULT: ow_usb_msg.c
333) Opened USB DS9490 bus master at 1:4.
Nov 5 09:20:54 wiregate723 OWFS[7124]: DEFAULT: ow_usb_cycle.c
213) Set DS9490 1:4 unique id to 28 38 69 DE 03 00 00 40
Nov 5 09:20:56 wiregate723 /usr/sbin/wiregated-ow.pl: INFO - No DS9490 found - owserver restart and fill cache..
Nov 5 09:21:41 wiregate723 monit[2644]: 'rootfs' inode usage 99.9% matches resource limit [inode usage>75.0%]
Nov 5 09:21:41 wiregate723 monit[2644]: 'rootfs' space usage 84.9% matches resource limit [space usage>80.0%]
Nov 5 09:21:41 wiregate723 monit[2644]: 'rescue_fs' inode usage 99.9% matches resource limit [inode usage>75.0%]
Nov 5 09:21:42 wiregate723 monit[2644]: 'owserver' process PID changed to 7124
Nov 5 09:21:42 wiregate723 monit[2644]: 'lighttpd' PID has not changed
Nov 5 09:22:22 wiregate723 OWFS[8465]: DEFAULT: ow_daemon.c
Nov 5 09:22:22 wiregate723 OWFS[8465]: DEFAULT: ow_usb_msg.c
Nov 5 09:22:23 wiregate723 OWFS[8465]: DEFAULT: ow_usb_cycle.c
Nov 5 09:22:24 wiregate723 /usr/sbin/wiregated-ow.pl: INFO - No DS9490 found - owserver restart and fill cache..
Nov 5 09:22:42 wiregate723 monit[2644]: 'rootfs' inode usage 99.9% matches resource limit [inode usage>75.0%]
Nov 5 09:22:42 wiregate723 monit[2644]: 'rootfs' space usage 84.9% matches resource limit [space usage>80.0%]
Nov 5 09:22:42 wiregate723 monit[2644]: 'rescue_fs' inode usage 99.9% matches resource limit [inode usage>75.0%]
Nov 5 09:22:42 wiregate723 monit[2644]: 'miniserv.pl' total mem amount of 61572kB matches resource limit [total mem amount>61440kB]
Nov 5 09:22:42 wiregate723 monit[2644]: 'owserver' process PID changed to 8465
Nov 5 09:23:42 wiregate723 monit[2644]: 'localhost' loadavg(5min) of 2.4 matches resource limit [loadavg(5min)>2.0]
Nov 5 09:23:42 wiregate723 monit[2644]: 'rootfs' inode usage 99.9% matches resource limit [inode usage>75.0%]
Nov 5 09:23:42 wiregate723 monit[2644]: 'rootfs' space usage 84.9% matches resource limit [space usage>80.0%]
Nov 5 09:23:42 wiregate723 monit[2644]: 'rescue_fs' inode usage 99.9% matches resource limit [inode usage>75.0%]
Geändert habe ich kürzlich was an der visu_config.xml. Aber das kann es ja eigentlich nicht sein, oder?
Wartungs VPN ist an. Der Name meines WG lautet: 723. Wäre euch dankbar wenn sich das bitte einer ansehen könnte.
Danke im Voraus und LG!
Mike
Mike
