About HS Web Pages/IP Devices analyse, what is the best way to troubleshoot that thing ?
If any one of the test condition is not met, there is no result. In the Debug list, Event-BiDir, I can only see a status OK=1 or OK=0, but no clue as to where there is a problem.
The only way I've found is to start from the end and delete 10 blocks at a time untill it works again
, and re-type the deleted lines, but that's not really a solution where there are over 320 lines.
Is it possible to work with cut & paste, or temporary copy of the file in order to avoid to have to type-in the whole file again, once the problem has been isolated ? It seems the HS doesn't work with filenames but rather internal IDs, is it so ?
Thanks in advance
Raymond
Thanks in advance
Raymond
