Hard to believe
Hello,
So, I called an expert to help me analyze the Wireshark trace.
The positive thing is that the problem is quite consistent, reproducable at will.
Upon close attention and many cross-checks, it appears that the dialog between the HS and the FTP server is not correct
when the session is initiated by the HS (missing ACK from the HS to the FTP server)
Although a dialogue initiated manually is correct.
The conclusion is that there might be a problem in the implementation of the TCP stack on the HomeServer.
Please don't flame me right now.
Yes, I know, it's hard to believe.
Yes, I know, there are hundreds, maybe thousands of HomeServer in the field whereof many are still running 2.8.
Why me ? What's so special about me ?
I didn't publish the troubleshooting session (in french) nor the Wireshark traces, but they are available upon request.
So, I'm having a problem with FTP, the writing of Remanentspeicher and some Webabfrage, well I think they all stemm
from the same cause, they poison me since months.
Webabfrage on mobotix T24
Some weeks ago, I noticed a problem with the Moxa NPort 5110, it looks like the Webabfrage is NOT executed at all, again
hard to believe, but ...
I called Moxas Germany excellent Support who took over my installation, the conclusion was: the NPort is OK, it's not
a Moxa problem, but rather software....
This problem is still pending as of today, no solution is available. In the mean time, the NPort has been replaced, no change.
I certainly do not want to start a polemic, my question is: How do I get out of this mess ?
The only way out I can see is to upgrade from 2.8 to 4.1 but then I bump into an unanswered question mentionned here
Anyone running 4.1 and the xxAPI ?
and here
Several parts of my Visu are based on the xxAPI and I would hate to loose them.
So, I ask again: Am I the only alien running the xxAPI ? and willing to move to 4.1 ?
Thank you to all who kindly helped me.
Hello,
and here
