I don't know of any Baustein exactly for this, but that doesn't mean, there isn't one ...
I have a Baustein, that allows you to replace 4 strings to 4 replacements. If you cascade this Baustein three times, then you can achive what you want.
If you only have one place (one KO), it's no effort, if you have (let's say) 10 KOs to translate, it might be easier to write a new Baustein.
The Baustein will have only 1 input (where the possible data are one of the 12 months) and one output (the translated month), but will be used at 4 different places.
You triggered some thinking, I checked for a similar Baustein and modified it for my needs. It's rather basic but works for the days of the week (next: the months of the year)
I'm doing a Webabfrage from weather.com, but despite the parameters specify "french" I get some text in english. That's OK now.
Anyone interested in testing the text translation Baustein ?
Although quite simple, might be of some use.
Don't know how to upload it in the new system.
