Baustein for text translation
    HS/FS Baustein for text translation
    Hello,
    Before I re-invent the wheel ... Is there any Baustein available for text translation ? or similar.
    From a Webabfrage I get the name of the months in english and I want to translate them in french.
    Thanks for any tip.
    I don't know of any Baustein exactly for this, but that doesn't mean, there isn't one ...
    I have a Baustein, that allows you to replace 4 strings to 4 replacements. If you cascade this Baustein three times, then you can achive what you want.
    If you only have one place (one KO), it's no effort, if you have (let's say) 10 KOs to translate, it might be easier to write a new Baustein.
    My Baustein is case sensitive.
    Regards,
    Hartmut
      Hello Hartmut,
      OK, I'll give it a try
      The Baustein will have only 1 input (where the possible data are one of the 12 months) and one output (the translated month), but will be used at 4 different places.
      Thank you for sharing your work.
        Hello Hartmut,
        You triggered some thinking, I checked for a similar Baustein and modified it for my needs. It's rather basic but works for the days of the week (next: the months of the year)
        I'm doing a Webabfrage from weather.com, but despite the parameters specify "french" I get some text in english. That's OK now.
        Thanks again for your input.
          Hello,
          Anyone interested in testing the text translation Baustein ?
          Although quite simple, might be of some use.
          Don't know how to upload it in the new system.
            Done!
