you should not make too much fuss about EX in privat homes.
Diesel or Heizöl is in principal difficult to ignite, it is not as dangerous as petrol, were the gas inside the tank is explosive.
We work with these units (without EX) in our tanks with different oils.
To programm the unit, I think you need an empty tank, or you measure the depth of the tank and place the unit in the same distance away from a wall and make the setting then. The difference is quite small (due to the different speed of ultrasonic in plain air or oily air) and you can correct it, when your tank is empty next summer.
