Baustein 9043
    Baustein 9043
    I'm using Baustein 9043 (Kategorie "Zeit-Funktionen").
    When comparing the output of the Baustein with the data from a local weather station, I noticed a time difference of 4min in the morning and 2 min in the evening. Isn't this a bit too much ?
    My house is 30Km away from the referenced weather station.
    While trying to clear the problem, I've setup the Baustein with the exact coordinates of the weather station, same time difference.
    Which one should I trust ? or, how could I cross check the data ?
    Thank you for your comments.
    No one is using this Baustein ?
    or maybe the time difference is acceptable ?
      Hi Raymond,
      the Homeserver logic module 9043 'Sonnenstand' calculates the results using an approximation formula. I have decided that it ist good enough for me after studying this.
      The (german) word in question to google for is 'Zeitgleichung'. If you have plenty of time, get a pencil, a writing pad (and not to forget a bottle of red wine), and then read the page mentioned above and compare here.
      Gruß, Rainer
        Hi Taxus,
        Thank you for the explanation.
        It's all in 2 words
        brauchbaren Kompromiss
        Sorry, can't do it
        I've plenty of time, and red wine, but no pencil nor writing pad (heck, I'm in France)
