Difference between Gira Busankoppler 1.0 and 2.1 ?
    KNX/EIB Difference between Gira Busankoppler 1.0 and 2.1 ?
    Hello,
    As far as i know, Gira made three Busankoppler Units:
    Instabus Busankoppler UP (Artikel-Nr. 057000)
    This one is used for all normal things: Tastsensors, Info-Display2, etc.
    Instabus Busankoppler UP 2.1 (Artikel-Nr. 064500)
    This one is only used for RS-232 Gateway (and i saw some people who used it for IR things..)
    Instabus Busankoppler UP 2.0 (same Art.-Nr as 2.1)
    This one is replaced by the above 2.1 version. I heard there were some problems with this unit.. ?
    Now, i'm in a house were they used ONLY Bussankoppler 2.1 Units, everywhere! For all tastsensors. It should be quite expensive... And it works!
    Is the Busankoppler 2.1 backwards compatible with the 1.0 version ? (something the 2.0 was definatelly not!)
    I just want to sort out this basic thing.
    Anyone ?
    Anyone ?
      Me
      It works - and it is nonsense
        Matthias, you also tried a Tastsensor with a Busankoppler 2.1 ?
          I never did. I'm no millionaire
          But, if you want, I will test it for you. I have some "on stock" ;-)
            Ok,.. please try... i'm curious..
            Can you also see if there's difference in the properties/device-info ? (in ETS3)
              I am going down to my cellar...
                Ok.. i'm waiting here..
                Maybe i need to screw one open.. and look if the same chips are inside.. ?
                Why did they named it "2.1" anyway.. ? (maybe you can use this one for 'future' purposes also.. ?
                  It works, as expected..
                    What's your opinion ?
                    Why don't they drop the 1.0 version.. and only make 2.1 versions.. then make it cheaper and nobody has to worry about which version to use where..
                      Are your really asking about logical decisions?
