mp3 player for homeserver
    Hello everybody,
    i would like to know how the mp3 player for the homeserver is working and if i like it where to buy.
    thank you,
    charly
    MP3 for Homeserver ? Only as an external system like Barix Extreamer or Logitech Squeezebox.
      homeserver
      I don't know either of the systems. Don't think someone have in Belgium. My idea is to control audio by means of the homeserver , use it a bit like an audio server for exemple request if it is possible offcourse?
      thanks,
      charly
        it´s possible to control MP3 by homeserver, but only external streaming clients as mentioned before.
        you can implement an control mask on your visual HS-client and control a streaming client like Squeezebox by commands over LAN.
        the homeserver is only the gateway for the commands and for visualizing on your touchscreen. there is no playing or mp3-encoding function in the HS.
        Mirko
          Then you have not yet looked at the correct places, there are in Belgium people who have experience with such systems and multimedia whit KNX in general.
          Grts,
          Daniel
            Are there any links to their projects? There exists several solutions to combine Audio with KNX but no special solution for the Homeserver. I think the problem is here the definition of "audio server".
            BR Jan
            Installation:
            HS2, BIQ+RTR, DALI-GW GE141, Visu über 19" u. 15" Touch, Gira MT701CT, Russound CAV6.6, Dreambox 7020S, iPhone, iPad, Nomos
              Hi and welcome Daniel,
              Statements are nothing worth here, without facts,
              therefore please post also the suitable addresses.
              That probably will be more helpful
              THX
              Raphael
              Der Kluge ärgert sich über die Dummheiten,
              der Weise belächelt sie.
              Nur die Weisen sind im Besitz von Ideen,
              die meisten Menschen sind von Ideen besessen.
                HS-JukeBox
                There is a MP3 player (for HS) if you also have running a Windows PC in your n etwork with free resources.
                The clue is to control the Player via HS and put all Informations of Player on the HS VISU...
                Have a look at HS-InfoJukeBox at the download section here...
                If this that what you are looking for, we can do here a tutorial "how to" ...
