I don't know either of the systems. Don't think someone have in Belgium. My idea is to control audio by means of the homeserver , use it a bit like an audio server for exemple request if it is possible offcourse?
Then you have not yet looked at the correct places, there are in Belgium people who have experience with such systems and multimedia whit KNX in general.
Are there any links to their projects? There exists several solutions to combine Audio with KNX but no special solution for the Homeserver. I think the problem is here the definition of "audio server".
BR Jan
Installation: HS2, BIQ+RTR, DALI-GW GE141, Visu über 19" u. 15" Touch, Gira MT701CT, Russound CAV6.6, Dreambox 7020S, iPhone, iPad, Nomos
