Dear colleagues,
I use an GIRA 217400 I00 dimmer. It seems only an I02 can do HVLED loads of 8 Watt and higher.
What happens when I connect leds to this dimmer? I suppose I need to load the channel with minimum of 20WATT? apart from that I can't see what the issue will be.
I suppose smaller loads (like 8WATT) will cause the dimmer to "flicker" the HVLED?
Since I need to buy a new dimmer anyway, which one do you recommend? It would need 4 channels minimum and should be capable of having most loads (halogen, hvled, ...)
Thanks,
Tim
Thanks,
Tim
Did you try to dimm any LED with the GIRA model I00? Any problem with this?
