Dimmer HVLED (Gira 217400 I00 hardware)
    KNX/EIB Dimmer HVLED (Gira 217400 I00 hardware)
    Dear colleagues,
    I use an GIRA 217400 I00 dimmer. It seems only an I02 can do HVLED loads of 8 Watt and higher.
    What happens when I connect leds to this dimmer? I suppose I need to load the channel with minimum of 20WATT? apart from that I can't see what the issue will be.
    I suppose smaller loads (like 8WATT) will cause the dimmer to "flicker" the HVLED?
    Since I need to buy a new dimmer anyway, which one do you recommend? It would need 4 channels minimum and should be capable of having most loads (halogen, hvled, ...)
    Thanks,
    Tim
    I've lately used the 3904REGHE from Jung and had no problems with any Types of Loads
      thank you for your help.
        Zitat von braest Beitrag anzeigen
        Dear colleagues,
        Thanks,
        Tim
        Hello,
        I have the same dimmer and the same problem.. Did you try to dimm any LED with the GIRA model I00? Any problem with this?
